Echo Show as an all-in-one, voice-activated smart TV. Integrates with something new called Fire TV Recast that sends live TV to your Echo Show as recordings.
Record 2-4 shows at a time, stream to multiple devices.
Put Fire TV Recast anywhere in your house and connect it to an antenna, and itâll beam those shows and networks throughout your home via Fire TV.
Iâm not, for all the reasons we discussed when the Echo plus first came out. âSimple setupâ onboarding is Amazonâs minimum requirement for their hub functions.
Setting up new smart home devices is easy. Just say âAlexa, discover my devicesâ and echo plus Will discover and set up compatible home devices.
OK, looks like youâll be able to give voice commands to any echo device and have the microwave work, which is the same way the GE Alexa enabled microwave works. So thatâs better.
Amazon has Z-Wave and they actually opened it up to others to use, but is not mounted on the Echo board, itâs on their Ring board
âToday, weâre excited to announce that weâre adding access control for Ring Alarm. Neighbors who buy a Z-Wave lock from Schlage, Yale, Kwikset, or Danalock will be able to lock and unlock their doors using their Ring app. Additionally, neighbors using the Schlage Connect or Danalock locks will also be able to disarm their Ring Alarm when they enter the code on their lock.â
I will be impressed if I can name my Alexa devices to whatever I want. I have too many Alexaâs in my life. Unfortunately, I cannot name my missus Alexa.
Computer, Amazon are your other choices⊠did you mean âunnameâ? I would keep the Echo as Alexa, that way you have a back up if one doesnât hear you.
