Aeotec Smart Home Hub/2018/2015 Model Hub Firmware Release Notes - 0.48.03
There’s a seperate topic on this. I asked if these drivers count toward the total number of installed drivers but haven’t gotten an answer.
Why SmartThings has installed unnecessary Wemo etc drivers to my hubs
Must be just the first I’ve noticed them.
And I’ll amend my earlier post - I thought I deleted them, since got no error with CLI, but they are still showing up :slight_smile:
Saw the wemo driver too, but it had found a Linksys range extender, so at least had one device. But the driver was reporting comms errors trying to reach it, so I deleted the device. Wouldn’t doubt if it pops back up again the next time I do an Add device…
With the force install of the ST unwanted drivers i find devices start to drop off my hub, they put me near 40 drivers, deleting them and 2 or 3 drivers now unused, stability returns and devices remain connected
For whatever reason the devices that drop off my hub are Ikea smart outlets, Ikea movement sensors and or a single Xiaomi temp sensor
I’m nowhere near the 40 driver limits, but also experiencing drop off issues with the Ikea Outlets
I removed the Linked Account information. I even deauthorised in Hue account. I selected the Hub to Hub connection, not the Linked Account connection.
Okay I can now see the Edge connection details in Meethue.com portal.
Follow up to my post regarding a problem caused by this firmware update to one of my drivers:
The SmartThings team has found the issue and will address it in their next update. In the meantime they’ve recommended a workaround which I’ve tried and it works.
Details For LAN driver developers:
When using the tcp socket receive() method, you can pass as a parameter the number of bytes you want to receive. YOU MUST NOW FORCE THIS VALUE TO BE AN INTEGER by using math.floor(), as in:
local number_of_bytes = 10
socket:receive(math.floor(number_of_bytes))
Otherwise, with the latest firmware update, Edge (C code) sees this parameter as a floating point number and this causes the error I reported earlier.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
