Hello, after connecting the Pico I can’t control it, I get the message “This device hasn’t updated all of its status.”
I have reset and reconnected it several times, but always get the same result ![]()
Has anyone else had a similar problem?
Did you install the vendor supported Edge driver?
Thanks for the response. Yes, I tried, and I have the same message.
The ST app is expecting some capability to be populated and the device is not supplying a response for it. I’d do some driver logging at this point using the ST CLI. Download the binary to your Linux/Windows/macOS computer and use the command “smartthings edge:drivers:logcat” and select the appropriate driver. Then click on the device in the ST app or pull down to refresh the data. Cut and paste the output here using the Preformatted Text option from the gear menu.
Contact Aeotec Support support@aeotec.freshdesk.com
You might have to delete the device and add it again after you have switched the driver.
The same result ![]()
Then you don’t have the vendor’s driver installed and the device is not using it
Click on this link to join the Aeotec Group channel and install the drivers that you need:
Direct Invitation Link: https://bestow-regional.api.smartthings.com/invite/8b2AZR9b06lv
Select driver that supports you device:
smartthings edge:drivers:installed listed me
when I try logcat smartthings edge:drivers:logcat a08a9eaf-3363-4912-b07f-01f1019d566a
I received 404:
Error: Unexpected error from event source Event { type: 'error', status: 404, message: 'Not Found' }
@h0ckeysk8er @TapioX @Andrew_Bartlett @Andreas_Roedl
Thanks for helping me.
Ultimately, I found the cause of the problem. I enabled Zigbee secure mode in the hub options, and after a few minutes, Pico started working.
Why was it disabled in the first place?
I don’t remember why I disabled it. The configuration must have been loaded from an old hub from a few years ago that I haven’t used for a long time.
Recently, after moving, I wanted to get back into smart things, and Pico is the first device I’ve just connected.
