Qubino/Shelly Shutter Edge driver
Hi All,
I tried to add the Z-Wave shutter device to the Aeotec Hub V3, but unfortunately, it recognizes it as a light button.
I don’t have much experience with SmartThings, but from what I understand, it’s necessary to install an Edge driver.
Where can I check if it has already been implemented?
While searching online, I found this guide from Qubino that provided custom handlers, which are no longer applicable today
(Integration for our z-wave devices on Samsung SmartThings - Qubino : Qubino Help Center).
Could you please help me?
Maybe this helps you
Add Shelly Qubino Device to SmartThings using Edge Drivers :
I followed this guide, but I don’t see the driver for the shutter.
Which one should I install?
I don’t have this device.
I installed it, but when I try to change the driver, it doesn’t appear in the list of available ones.
However, when checking the installed drivers, it’s there now. Do I need to configure something to associate the new driver or it’s not compatible with shutter device?
Probably so
You should try to uninstall and reinstall.
How to remove or factory reset Z-Wave Devices.
Open SmartThings app.
Find your hub in the SmartThings dashboard, and tap it.
Tap More Options (3 dot icon)
Tap Z-Wave Utilities
Tap Generic Exclusion
Ensure the LED on your Smart Home Hub is flashing its green LED.
Tap the button on your Z-Wave device to factory reset it.
Notes
The button press required will vary between different Z-Wave devices. Typically its just a single tap to the button.
More uncommonly, it is 3x button taps within 2 seconds.
If successful, your SmartThings interface should state it has removed a device.
Now try connecting/pairing as you usually would.
Further reading
