I’m a little confused in regards to the OUTPUT, it says it should be connected to the LOAD, but should it be the LOAD LIVE or NEUTRAL? Or does it not matter?
But others show connection to LIVE.
(can only post 1 image per post, will reply with the image)
Even the manual shows output going back to LIVE
(C) goes back to the LOAD so it must be the LIVE, as NEUTRAL is comming from (B) ?
The OUT terminal is live and goes to your light or power socket that needs to be switched. The left side diagram on the last picture is a bit confusing bur seems to indicate the wires going back to the trunking so use the first picture.
Looks OK. You must just also tie the 2 green earth wires together for safety sake.
Edit: If you are going to put this in a metal box, the 2 green earth wires must also be screwed to the box. If plastic box, you just tie them together.
