Aeotec multisensor 6 no lux uv
hi,
I recently bought aeotec multisensor 6.
The pairing went all good, but the device is not reporting lux and UV (they always report 0 in various condition), but temp humidity vibration and motion are good…
Can u help me?
PS. I used aeotec multisensor advanced As DTH
It only reports lux about once every 60 minutes, it takes a long time before you get the first reading, and then it only reports when there’s been a change. So a lot of people have said they have to let it just sit for about two days before it starts giving readings they can use.
Aeon MultiSensor 6 - Reporting 0 Lux
I’ve had 3 of them for a few years, USB powered. I never got any UV reading on any of them. LUX is reported every time there is a change, regardless of time interval.
How? And which DTH do u use?
UV Reading is not important to me, but lux one is fundamental…
Same like you.
This sensor is 2 days on direct light and maximum luminance I got is 135 lux…!
EDIT: Now it’s reading 248 lux (direct light!), but the indicator bar is in the middle… It seem that a multiplicator is lacking…
Screenshot_20200807-092916_SmartThings|230x500
Here are my screenshots
And this is the DTH https://github.com/erocm123/SmartThingsPublic/blob/master/devicetypes/erocm123/aeon-multisensor-6-advanced.src/aeon-multisensor-6-advanced.groovy
Sometime ago I updated firmware to latest available, but it worked OK even before.
Also, here is a. informative guide https://aeotec.freshdesk.com/support/solutions/articles/6000156717-troubleshoot-multisensor-6-sensors-light-humidity-temperature-uv-
Thank you very much, I got finally the correct reading!
Only a problem now: although the value Readings are set up to 10 minutes, I got readings only every 60 minutes instead…
Other forums say the device will report UV, but not indoors. The only way to get it to report a nonzero reading is to take it outdoors.
