I have 2 Aeotec multi sensors, an Aeotec multi 6 and an Aeotec multi 3
The multi 6 reports all output in ST fine but the 3 is missing any humidity readings and nothing in the graph for temp or humidity
It may be the device has no humidity sensor, I can’t remember if it has the capability or not but it does have temp, so it should have a readout of temps in the graph
Any words of wisdom to make the graph work ?
All standard DTHs I have never changed the DTHs for these devices
No not at all Peter, the only reason I mentioned it was the graph and display shows humidity as in screenshot above, I couldn’t remember whether it had it or not
