Remove humidity graph from temperature/humidity sensor
Hello, looking for a way how to adjust temperature reporting with temperature/humidity sensor. I have 2 sensors, one is radiator head which only measure temperature and the second one is Aeotec temp./humidty sensor
The problem i have is with the combined temperature/humidity sensor.
The scale is completely different because humidity is more or less at stable levels.
So the question is, can i somehow take the temperature values out of the temp./humidity sensor and monitor it separately on its own ?
Hi @Safire
The graphic is combined by default and cannot be separated
In this example that you post, the problem is that you have a reading of 10°c and then the whole scale loses precision for the rest of the other much higher values.
I think you would see exactly the same graph if you did not have the humidity information.
This is one example for one device with and without humidity
Thats the another problem with the reding graph, i do not know why it reported 10°C + it disconnect couple of times daily, can you recommend some stable temperature sensor, without humidity ? My radiator head works okay but i cannot find similar temp. sensor and i have tried 3 brands already, but all of them have humidity sensor and random disconnects
I use the Aeotec zigbee (smarttings) motion sensor and multipurpose sensor and they work very well with the configuration of temperature reports.
Motion sensor has a big battery with a duration of more than 2 years
I think the Aeotec(smartthings) zigbee button also works fine, but I don’t have it
