In essence the changes from the outlet standard code are changes in the config messages to the device and then reading the data it sends in the correct format. Also I know understand as stated the Configure button is a one time needed thing to send the config to the device and the kWh is an cumulate number.
Other than that, I’ve added some debug logging and tarted up the device page tiles.
* Copyright 2015 SmartThings and gpsmith
* Based on original implementation by SmartThings but fixed some of the issues.
metadata {
definition (name: "Aeon Outlet DEBUG", namespace: "gpsmith", author: "SmartThings and gpsmith") {
capability "Energy Meter"
capability "Actuator"
capability "Switch"
capability "Configuration"
capability "Polling"
capability "Refresh"
capability "Sensor"
command "reset"
fingerprint deviceId: "0x1001", inClusters: "0x25,0x32,0x27,0x2C,0x2B,0x70,0x85,0x56,0x72,0x86", outClusters: "0x82"
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
for (int i = 0; i <= 100; i += 10) {
status "energy ${i} kWh": new physicalgraph.zwave.Zwave().meterV2.meterReport(
scaledMeterValue: i, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
tiles (scale: 2) {
multiAttributeTile(name:"switch", type:"lighting", width:6, height:4, canChangeIcon: true) {
tileAttribute("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#fdbc32"
attributeState "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
valueTile("power", "device.power", decoration: "flat", width: 3, height: 2) {
state "power", label:'${currentValue} W'
valueTile("energy", "device.energy", decoration: "flat", width: 3, height: 2) {
state "default", label:'${currentValue} kWh\n(total)'
standardTile("reset", "device.energy", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:'reset kWh', action:"reset"
standardTile("configure", "device.power", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch","energy","power","refresh","reset","configure"])
//details(["switch","energy","reset","refresh","configure"])
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x32: 3])
if (cmd) {
log.debug cmd
result = createEvent(zwaveEvent(cmd))
return result
def zwaveEvent(physicalgraph.zwave.commands.meterv3.MeterReport cmd) {
if (cmd.scale == 0) {
[name: "energy", value: (String.format("%6.3f", cmd.scaledMeterValue)), unit: "kWh"]
} else if (cmd.scale == 1) {
[name: "energy", value: cmd.scaledMeterValue, unit: "kVAh"]
else {
//log.debug "Fallen to W"
[name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W"]
v2 didn't seem to be working.
def zwaveEvent(physicalgraph.zwave.commands.meterv2.MeterReport cmd) {
[name: "energy", value: cmd.scaledMeterValue, unit: "kWh"]
else {
debug.log "Fallen to W"
//[name: "power", value: Math.round(cmd.meterValue), unit: "W"]
//[name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W"]
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
name: "switch", value: cmd.value ? "on" : "off", type: "physical"
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
name: "switch", value: cmd.value ? "on" : "off", type: "digital"
def zwaveEvent(physicalgraph.zwave.Command cmd) {
// Handles all Z-Wave commands we aren't interested in
//log.debug "Unhandled: ${cmd}"
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.meterV2.meterGet().format()
def refresh() {
def reset() {
return [
zwave.meterV2.meterReset().format(),
def configure() {
log.debug "Send Configuration to device"
delayBetween([
//zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 8).format(), // energy in kWh
//zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 300).format(), // every 5 min
zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 4).format(), // energy in Watts
zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 5).format(), // every 5 sec
zwave.configurationV1.configurationSet(parameterNumber: 91, size: 2, scaledConfigurationValue: 1).format(), // Send report for a 1W change
zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 8).format(), // energy in kWh
zwave.configurationV1.configurationSet(parameterNumber: 103, size: 4, scaledConfigurationValue: 300).format() // every 5 min
