I have the aërQ Temperature & Humidity Sensor which now works out of the box with the type Z-Wave Mold Detection. ST sees temperature and humidity. However, Alexa can only see temperature with this sensor.
Am I correct in understanding that Alexa cannot report any type of humidity and that there is no way around this?
The only way around for now is to use a smartthings routine (not an Alexa routine) to set a virtual switch at a specific target point and then you can ask Alexa if that switch is on or off. Or have Alexa notify you.
That’s OK if there’s just a specific threshold that you want to check for, like over 65%, but it’s less convenient if you need to check more than one target point.
