Aeon Labs Z-Wave Plus Recessed Sensor Gen 5
Paired and used with no problems. Now after three days, the battery reads 0% and the sensor is no longer functioning. I installed a new battery, removed the device, and paired again; pairs with no problems but still doesn’t properly work. Any advice?
have you tried the community device type?
Oddly, didn’t do anything and now the sensor gen 5 works properly and the battery condition also accurate. Go figure. Thank you for your help, and if the battery issue comes up again i will try your solution.
