I just purchased an Aeon Labs Multi-sensor (Gen5) and when I select "connect a device " in the Aeon Labs Multi-Sensor tab under “Things”, it says a device has been found but not the correct type. It does shows up as a generic Z-wave device but I am unable to configure any of the sensors.
After speaking with Smartthings, it appears that Aeon Labs has changed their chipset and the Z-wave Generation 5 is not yet supported on this platform.
Has anyone had any luck pairing the Gen5 version of this sensor?
@JB872 if it’s Gen5/Z-Wave Plus it probably needs an updated device type for the secure part of z-wave plus. A few Aeon Gen5 devices are working with updated device types. I don’t think there is one for this yet, but I’m sure it won’t be long.
Haven’t heard of Aeon Zwave plus multi in US of A. I have a 5th gen. Aeon Siren which works thanks to @duncan. Don’t have the recessed doir sensor but @beckwith is right as I read it too.
I so wish I could help with this but I am in the same category as you. I follow this community and learn. This community is the new Facebook for us… as far as I am concerned SmartApps may be but device handlers… I will definitely brick it for you if I tried!
Thanks for taking the time to look into this. Unfortunately I wasn’t able to connect and I was wondering if it has something to do with the Gen5 having a different raw description.
For the door sensor even though the thumbprint was different you could just change the device type from the dev API and it worked. Have you tried that?
I tried changing the device type to 0x0701 and I was able to connect to yours but it is not polling any data. Is there anything else I would need to change?
Unfortunatly this means the change is something more involved that I can’t make without an actual device. Sorry.
The fingerprint only deals with detection of the device. It doesn’t change anything about the device functionally. I don’t worry about them until I have a working device type.
