@Smartthings, are there plans to support the gen5 version of this sensor?
Yes weāre working on it (as of yesterday). It should be available soon if there are no complications.
Sorry weāve been slow to support new devices. We are under-staffed in the device development and submission approval dept but weāre working on that. Also sometimes we get advance info/samples of devices and sometimes we miss them.
According to this website, you can update the multi sensor firmware with a PC, but you canāt use the included USB cable as it only supports power. Obtain the correct USB data cable and you can update the firmware.
The firmware is available here and once unzipped, itās an .exe file:
http://aeotec.com/z-wave-sensor/1270-multisensor-firmware.html
Hi Duncan,
Itās good to hear you guys are on top of it.
Off topic, but any word on when we might see the official Nest integration?
There is now an official device type published for the Aeon Multisensor Gen5, so give it a try and let me know if you find any problems. We still have some testing to do before adding it to Works With SmartThings.
Hi Duncan,
Iāve been using this device type for the past couple days and it I now have readings reporting back to the app. The motion sensor seems to latch on to the ādetected motionā state for several minutes even if there is no motion in the room. Is there a delay programmed before it switches back to āno motion detectedā? Also, should the activity monitor be reporting everytime motion is detected or only when the sensor changes state? If I have a ādetected motionā alert I am unable to trigger another alert unless it changes back to āno motion detectedā first.
thanks for you help
Iām having the same problem. If this is how the new version works Iām going to ship it back and get another old one, this behavior is irritating.
edit: After more testing it appears that the motion sticks on for 4 minutes. I can repeat this behavior over and over. Trigger motion, āhideā the sensor so it canāt pick anything up, and exactly 4 minutes later it will go back inactive.
So it looks like the 4 minute thing is the default latch time. Here are some docs on the config parameters for this device.
@duncan Iām not sure if your team has been in contact with Aeon Labs on this but these values might be helpful.
After digging into the new device code it looks like itās setting this value to 60s and everything lines up to the docs above. Wonder why this configuration value isnāt being set correctly?
I just received my Aeon Multisensor Gen5. It included with no problem using the default device type, and is sending data. I have it powered by USB, so it should be awake and listening at all times.
But I canāt figure out how to send the configuration command to update the default parameters.
Iāve added a configure standard tile, but clicking it doesnāt appear to actually send a configure command.
Anyone have any thoughts on how to actually send that command?
After reading this threadā¦whatās the verdict?
Should I get the v.1 or Gen5 version of the Aeon Labs multisensor? The added antenna distance is not a good enough justification for my situation. What other HW improvements the Gen5 version has over v.1?? The price is the same and although I like to buy the latest technology, I rather connect without modifications. Which one should I get? (outdoor installation)
Thanks for your advice,
Y.
Iād say at this point itās a coin flip. The ST driver works, with the exception of the 4 minute latch noted above. ST hasnāt announced full support of this device yet, but Iāve been in contact with support and they are aware of this issue and are actively working on official support (which I hope means setting the motion timeout value correctly).
If you donāt mind waiting for the 4 minute thing to be resolved, Iād say go for it. It does get you into the new 500 series Z Wave radio which seems like it might be helpful moving forward.
Reply to my own post - I was able to set the configuration by using the Configure tile I added to the device type.
It seems that even in USB powered mode, you still have to set the sensor into a state where the LED is blinking before it will accept a configuration command.
After much trying (and not knowing what the final combination of press/hold the button on the sensor turned out to be), my sensor is updated. Itās now reporting No Motion after 60 seconds.
I may update that again to 15 seconds, since Iām not worried about power usage.
Can you share your code for the config tile?
I updated the Tiles section to this:
tiles {
standardTile("motion", "device.motion", width: 2, height: 2) {
state "active", label:'motion', icon:"st.motion.motion.active", backgroundColor:"#53a7c0"
state "inactive", label:'no motion', icon:"st.motion.motion.inactive", backgroundColor:"#ffffff"
valueTile("temperature", "device.temperature", inactiveLabel: false) {
state "temperature", label:'${currentValue}°',
backgroundColors:[
[value: 32, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 92, color: "#d04e00"],
[value: 98, color: "#bc2323"]
valueTile("humidity", "device.humidity", inactiveLabel: false) {
state "humidity", label:'${currentValue}% humidity', unit:""
valueTile("illuminance", "device.illuminance", inactiveLabel: false) {
state "luminosity", label:'${currentValue} ${unit}', unit:"lux"
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'${currentValue}% battery', unit:""
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
main(["motion", "temperature", "humidity", "illuminance"])
details(["motion", "temperature", "humidity", "illuminance", "battery", "configure"])
Weāre still trying to figure it out. I havenāt been able to replicated the problem myself.
I got this problem too
I just connected two new sensor but one of them is stuck in active motion while the other is stuck in inactive motion. Is anyone else having this issue too?
Can I check my current firmware ? How ?
And after I connect with USB cable that support data transfer, how to update the firmware ?
