wish I bought some earlier. I didn’t realize they were removed from the smart store. can anyone comment on why they were removed? supply or reliability?
@urman Any idea why Aeon Labs Door/Window sensor is not an option in the drop down list anymore? I’ve had the recessed for a couple months and was troubleshooting tonight why I don’t get battery status. Found this an another thread that mention to change it to Aeon Labs Door/Window but I can’t find it in the drop down and I can’t seem to find any published groovy code for it.
If I recall, it basically became a mirror of Z-Wave Door/Window Sensor. So we rolled it into that.
I kinda wondered if that was the case, so I should contact support about the battery level not reporting?
I just bought two of these and paired them to my hub. Sadly it came in as a “Z-Wave Device” and doesn’t report any activity. The model number is ZW089-A. I tried to change the device type via the IDE but still no activity is reported. Can anyone help?
Thank you.
Assuming it is Gen 5
I’m having no luck adding the devices to ST. I Select to add the new device, then press the button on the sensor, led blinks three times, but device is not added. What am I missing?
Hub reset did the trick…devices added now.
Anybody monitoring this thread somehow set this up to monitor deadbolt status?
If you use the dashboard you can create a shortcut that will show closed/locked as one icon
Ok, can that magnet that’s being sensed fit over the end of the bolt in a deadbolt? I saw an instructable with an insteon sensor done as such. I wish I could see the device completely.
nope, just tried it 4321
Darn. I have a spacial problem with the deadbolt on my new back door, plus I don’t really need remote control. I just want to know if it’s locked. Any thing you’ve seen like that?
well you could maybe attach a open/close to the thumb turn that will register closed when locked. Might look silly. Even though you don’t need remote access in another thread it was mentioned that Target has schlage smart locks for $140, normally $200.
I guess the Camelot does have a smaller footprint. Maybe that would not interfere with the add on enclosed blinds I’m getting.
Same here. Was working fine and now won’t report any activity or open status. No battery level either.
