Aeon Labs Energy Meter clamps
There are two resets which one left or right?
“Reset Watts” is the left. Doesn’t the tile say that? If not, then iOS is having text scaling issues (also a known bug).
Sorry to say it doesn’t say which reset is for what. But you were correct it works now. Any idea on the Smart Power Outlet?
Great… Looks like ST has more work to do fixing more issues. Just remember reset watts on the left, and reset kWh on the right.
I don’t have a custom device handler for the outlet, I just use ST’s default. There’s a developer’s conference call tonight, so maybe ST will shed some light on when all the broken things will be fixed.
If you hear anything please let me know. Things like this I expect from Microsoft but not ST.
Just received this from ST support:
Thanks for contacting SmartThings support. I’m sorry to hear about your power usage devices no longer displaying their their consumption status. This is something that our developers are aware of and working to remedy. I have tagged your email address to be notified when we release a fix.
I can duplicate the below with my HEM…
@Mike_Maxwell
Can you clarify one more time about the buttons?
I see the boxes displaying data in the device within the ST app, but when it comes to interacting with them through Rule Machine, the only option that I could find was ‘switch’; don’t see anything named ‘button controller’. I know I’m probably just missing some piece of brain code…
Then, it’s just one thing, not two.
i.e. I can’t make rules based on whether one or the other is on or off.
I can only make them based on whether either are on or off.
If side A is on, then the whole switch is on.
If side B is on, then the whole switch is on.
Do you know what I mean?
It’s not horrible. The main point I care about anyway is, ‘Are either of these appliances on?’.
So, if it’s just that and I misunderstood, it’s totally fine with me and already serving the intended purpose. :slight_smile:
@johnconstantelo, based on your screen shot, it seems that the device is reporting battery correctly. However, using your device code, my has been reporting 0% battery for almost 2 days now, and I have new batteries installed.
Hi @damohabir, unplug from USB power for a few minutes and then plug it back in. Let it run on batteries just for a bit. That’s what I did.
@sgnihttrams, buttons are available in the trigger or conditional trigger section.
The buttons will fire when the connected appliance wattage transitions below the what you have configured.
The switch is on if either alliance is on, and off when both are off.
@Mike_Maxwell
Sweet.
So, perhaps, for my kitchen cooking odors rule, I will use the switch to trigger turning the HVAC fan on, and then use the buttons to trigger turning it back off after a delay (if that’s possible with those buttons).
Obviously, when I get around to setting up my other v1 HEM, I will use it pretty much like you use it for my washer/dryer laundry tasks.
Thanks! :slight_smile:
Yea, that should work as expected.
@Mike_Maxwell
One more question about these things…
If I want to maximize the usefulness of a v1 HEM (staying in the same use case vein as we just discussed to get me going), would it be OK to put a clamp around more than one appliance’s power cord in order to, let’s say, monitor two or three or more appliances?
I know that it would only tell me that some device in the set is on, and I wouldn’t be able to know which one.
I’m just thinking, if what really matters in this use case (my kitchen cooking odors rule) is knowing that ‘something’ is on, it shouldn’t matter which one, right?
no reason not to, but it might be better, (read easier) to move the clamp over to the breaker that runs your kitchen.
Running multiple split cords through one clamp is sure going to look ugly, if it’s even physically possible…
Ya, my breaker box is a bit of a kludge, and requires the power company to come out to unlock it in order to even get into where the mains are (TLDR)…
So, although I could do what you suggested, if there’s another way to do it without getting into all of that, I’m going to hold off on that until or unless it becomes absolutely necessary (like when I eventually get around to putting one out there to monitor the whole house).
Fixed the problem in rendering on the following lines. All I had to do was on the label line remove the 'n" in front of Watts and Energy and the line renders properly.
standardTile(“resetmaxmin”, “device.energy”, width: 3, height: 2, inactiveLabel: false, decoration: “flat”) {
state “default”, label:‘Reset\nWatts’, action:“resetmaxmin”, icon:“st.secondary.refresh-icon”
standardTile(“reset”, “device.energy”, width: 3, height: 2, inactiveLabel: false, decoration: “flat”) {
state “default”, label:‘Reset\nEnergy’, action:“reset”, icon:“st.secondary.refresh-icon”
Good find @joelw135. I made the change to my code as well, and github has been updated. It’s too bad we keep finding differences in how ST’s app looks on iOS and Android, but I suppose trying to keep things the same across two very different os’s is a bit challenging.
I am still trying to find a way to fix ST’s problem with the Power Outlet not showing power in IOS, so far no luck.
I know this is a bit old but I thought I would share what I did.
I installed an outlet and extra breaker inside my electrical box. I live in an apartment so I didn’t want to punch a hole on sides of the box. I just got two feet of 12AWG conduit from Lowe’s ($1.60 I think), a 20A breaker (under $6), a “slimline” plastic wall box (under $2), an outlet ($1.50, tamper-proof), and a cover. I then wrapped the outlet and everything in electrical tape.
Here it is from the outside (the solo breaker at the bottom is the power meter breaker).
And from the inside. My hub is about 20 feet from the breaker box and I haven’t had any range issues in the past week since I installed it.
