tgauchat
264
I was already pretty confident of this hypothesis, but I appreciate the concurrence. It would be super convenient, of course, if the ADT Panel’s “screen” could run a browser that runs ActionTiles, but that’s too much optimism!
If the Capabilities I mention in my previous post are official (and documented), then I am hoping we will be able to develop a way to use Capability "Bypassable" from inside ActionTiles. This may or may not be easy, so we wouldn’t jump right on it, but it’s nice to envision being able to replicate this critical convenience function in directly in AT. Anything we can do to keep Customers from having to use non-ActionTiles apps or dashboards is a good thing in the long term.
Me too!! I already tested the new panel and ST app integration with my wife and she said “Finally! Something easy to use”. We currently have Spectrum Intelligent Home and it’s app leaves a lot to be desired. Not to mention they’re abandoning their security offering. I’ll be glad to have a real monitoring company monitoring a seemingly awesome platform. Now to finish moving all of my devices over from my current v2 hub. (that I just migrated to two months ago!!)
You’ve got more motivation than me. Honestly, I’ll probably end up keeping the ADT system on its own segment for a while in hopes ST may release a migration tool. I realize this has been a long requested feature with no sign of happening but my hope is ADT will motivate ST to finally do it. Regardless, all doors and windows now have standard ST sensors and ADT sensors so I’m not missing much functionality keeping things separated right now.
On a side note, I noticed the ADT panel has a hidden USB port. I wonder what it will eventually be used for (if anything).
I just finished creating two SHM pistons that both monitor and set the alarm system. I’m sure there’s probably a way to create a single piston for this but my version requires two pistons. Here’s the code if anyone else wants to do it:
Piston to monitor security system status and set SHM to match it:
Right now the answer is no. We don’t use the cellular radio in the case of a power outage. The cellular radio is only for the ADT security devices and service at this point in time.
Ugh… it looks like someone removed the ability to control the panel via CoRE. It’s no longer responding to any commands and its back to being a dumb alarm.
I noticed last night around 6PM CST my panel got a new update. It downloaded a new system image, installed it and rebooted. I wonder if something got “patched”?
On another note, have you been able to sign up for ADT monitoring yet? When I try to register, it still says “Coming November 5th”
Edit: Nevermind… ignore my rambling. I’m an idiot. See @JDRoberts post above.
Yeah… it sure seems like it got patched. It’s not even possible to monitor the alarm status anymore. If this is indeed intentional it pretty much makes the ADT/ST Panel pointless, at least in my opinion. There is basically nothing unique or particularly interesting about the security system. It’s just your typical manual arm/disarm system with no support for anything… you can’t even setup a basic schedule or control the system via a routine. The only thing ST about the system is that there’s a hub built into the panel and that’s it. In other words, there is nothing ‘smart’ about the alarm system anymore.
In regards to the ADT service: I’m getting the same message. That makes two missed dates now (1st and 5th) unless it becomes available in the next few hours. Regardless, I’m going to give it a few days but I’m already leaning towards returning the system.
You were absolutely correct – I’m an idiot. There was a panel patch released today and I updated webCoRE and nothing continued to work yet other pistons were firing. I thought this was clearly a sign something had changed but I just noticed another webCoRE patch was released ~15min ago and that completely fixed it. All is back to normal.
tgauchat
276
I don’t want to be right about this one, but I did make this prediction in an earlier comment Oct 27th:
SmartThings is very predictable. Please SmartThings … prove me wrong this time! Thanks!?
I was actually wrong – it’s back to working exactly as it originally did with the usual commands. It turns out it was a completely unrelated webCoRE issue. Essentially, ADT/ST coincidentally released an unrelated ADT Panel update at about the same time a widespread webCoRE outage occurred (possibly due to the time change).
Your point and concerns still stand though. I’m definitely concerned this sort of functionality will break at some point since there’s no official support for it. With that said, I personally feel it would be an incredibly stupid move on ADT/ST’s part because it would make the alarm system no different than any other system out there. In fact, even some basic functionality is missing out of the box (e.g. the ability to configure alarm schedules).
tgauchat
278
Yup… Let’s hope @slagle or @Jim or @unixbeast or …?, can confirm that the newly discovered Capabilities are official, will be documented, and not blocked on the ADT or similar “Devices”, and thus accessible to Community Developers. ref:
It’s live! I just signed up without any issue. You get 60 days of the top tier service free and you can’t select anything else (yet). This is a bit random for people who don’t have smoke/co alarms and water leak detectors because if you forget to cancel or modify the service after sixty days you’ll get charged for service you don’t need. I don’t have these ADT devices so I just set up a reminder to change the service in sixty days.
Just a heads up: When you activate the system it doesn’t immediately tell you to do a systems test. However, when you login to ST it says “System test required” in small letters above the alarm status. You have to click that text and run through the test before you can use the system.
I’m going to have to wait to do the test because it’s late here and it apparently requires intentionally setting off the alarm siren.
You must be a mind reader! haha I just finished the enrollment on mine and got the message about a system test. It’s late here too and my kid just so happens to sleep in the room where the panel is located. So, I decided to keep the Wife Acceptance Factor in my favor I would need to wait and test in the morning.
So far I have to say I’m impressed with the ADT signup process and how simple it was.
I definitely agree about the setup process – it was very easy and straightforward. The other cool part about the ADT integration is that it’s 100% integrated into the ST app. In other words, the ADT account is managed directly from within the ST app so there’s no need to actually visit ADT’s website. It ends up being a really seamless experience which I really like.
My next project: Limited security system control via Alexa. I plan to create an Alexa command that arms the system in stay/away mode only. I don’t really want/need it to disarm because I feel like that’s a security risk and I always disarm via phone, panel, or keyfob anyways. With that said, it should be possible to enforce a voice pin when disarming the system via Alexa using the Ask Alexa smartapp.
This leads me to a feature I hope to one day see: The ability to control the ‘panic alarm’ capability in webCoRE (assuming ST cooperates with this sort of integration). With this functionality, it would then be possible to trigger the panic alarm by voice only through Alexa. As someone with an elderly parent who is prone to falls, I would most definitely implement this. You could even create an “under duress” voice trigger in the event of a home invasion robbery scenario (e.g. Alexa, ask SmartThings to turn off ‘home security’). In this scenario, ‘home security’ would really be a virtual switch that triggers the panic alarm.
