Can anyone tell me if a product, such as Delaney locks that aren’t advertised as supported with smartthings, can be manually added so they can function through the smartthings dashboard?
Also, can anyone tell me if Delaney z-wave locks will be supported by smarthings in the future?
Looks like a pretty standard device, if it’s what you really want I think it’s pretty safe to buy it. It will probably be detected as a zwave thing and you’ll just have to change the DTH to zwave lock. Obviously, buy from a place with a decent return policy in case I’m wrong
Thanks for that, It is a sample so I’m not worried about the refund, but t is for a builder that is determined to use this lock. I will try to make it discover again but it did not when I tried it.
For locks (at least the schlage I have) you may need to bring the hub very close to it, 10ft or ideally less to pair them. I think it’s a security thing while pairing. If that doesn’t work put the hub into exclusion mode and try to exclude the lock before trying again to re-pair it. Good luck!
RBoy
6
Based on the specifications provided by the manufacturer, it should work with the Enhanced Z-Wave Lock DTH. A few things may need to be added to report it’s capabilities to ST correctly to get use of the advanced features of the lock. @Goff001 if you decide to get the lock and use the DTH, ping me and we can go into more details.
Just a note that this lock uses S2 where as the v2 hub only uses S0 for now. V3 may support S2, but it should work fine AFAIK.
V3 Will support S2 eventually, that was part of their zwave certification agreement, but they were granted an extension. I don’t know for how long, though.
