The easiest way to do this is with a webCoRE piston. However, if you don’t want to go that route, then you could use something like SmartRules or Stringify. I don’t think there is a way to add that kind of a conditional into a routine.
Honestly, I would create a simple piston to do it.
Thanks a lot. Didn’t know about webCoRE. I got it installed and deleted all my routines now haha. I am going all through CoRE. This is way better. This is the first thing people should get when they install a SmartThings hub!
Follow up question for you sir. Trying to have webCoRE send a notification when an invalid door code is used. Totally get when a code is used to send a notification but can’t figure out about an INVALID code. I posted something already but I haven’t heard from anyone.
Otherwise, for z-wave, you can search through the forum for a DTH for your particular brand.
With all that said, I believe that the invalid notification in webCoRE might be tied to the DTH and not the smartapp so much, but I’m not 100% certain of that. So, changing out your current lock’s DTH for an “enhanced” version might be just what you need.
RBoy
5
That’s absolutely correct. Invalid notifications have 2 things that needed to be done for it to work. One the lock must support sending it. Different brands behave differently, for e.g. Schlage locks will send an invalid notification on every 3rd or 4th invalid pin entered (depending up on the model) where as Yale locks can be configured to send the notification on every entry.
2nd and equally importantly you need a Device Handler that can capture and process those notifications and report them to SmartApps like CoRE or the Lock Multi User Management app @Core_Phx pointed to above.
This is a device handler that support enabling/configuring the invalid pin feature on the lock and then also capturing the reporting the same.
