So cool to see everyone’s ideas and interpretations. Here’s a link to another cube project from @CyrilPeponnet
https://dl.dropboxusercontent.com/u/2663552/Github/Smartthings/theCube/IMG_0758.jpg
I’m waiting for someone to post a 3D printed version (and the design file). Then I’ll just take it to our local library and print it out! (Yep, I’m that lazy these days )
I was actually thinking of printing one. Maybe Ill do that this weekend.
I just finished creating an .STL file for my version of the mood cube. Just started printing it. We’ll see how it comes out. The idea is the two parts will snap together and then I can print different side covers with different text and/or in different colors that will snap into the main cube. The multipurpose sensor slides into the the part on the left.
On the left are the two halves and on the right is the two parts paired together. The ‘Off’ tile has extruded text and will be all one color. The ‘On’ tile is negatively extruded and will be printed in two different colors. The blank tile will just be printed in the color it represents.
Nice! Eventually I plan on making a off,on,stop,low,med,high cube for my fans with lights. Will be cool to see how yours turns out.
Here is the initial print. It was printed at fast speed so it is a little rough. This was also done in ABS instead of PLA and I haven’t ‘sweated’ it yet. I"ll do the final print with PLA so it will be smoother. Since each color prints a little differently and requires minor tweaks to the extrusion settings to get a perfect print I am going to change the design. When I get time I will make the panels slide into the sides opposed to snapping in so my tolerances won’t have to be so tight.
THIS IS AMAZING! What sensor is this? Will this work on Apple iPhone iOS SmartThings app? I NEED TO make one? Do you happen to have a build video? Thanks!
You just need a sensor with an accelerometer so you get X, Y, and Z axis reports. So you can tell that it turned in three-dimensional space and Where it ended up.
Most people use the SmartThings multisensor for this. The mood cube smartapp works in the official SmartThings app regardless of the phone version, I believe, but you only need that during initial set up.
First pair the sensor to SmartThings. Then build your cube and install the sensor. (Make sure you can get it out again to change the battery.)
Now you are ready to install the mood cube smart app.
Two) choose marketplace
Four) choose lights and switches
THIS IS AWESOME! Currently building my Cube! Ill post pics and any issues I run into. Im hoping the “Save Current Light State” will work for me as I have read it hasn’t for so many. I have 5 lights I will be building into this idea. Wish me Luck! @JDRoberts @Pete
HI guys,
I have a few questions/comments about the Mood Cube set up. Here’s where I am:
I secured both parts of the ST multi sensor inside the cube (because only one part throws my SHM off when in Arm (Stay) or Arm (Away) as it reads open. I was able to “Record Current Light Status” only once. After that it wasn’t able to record one scene after another. It kept recording the SAME SCENE (the first scene recorded). However, I used the following process to get the “Record Current Light Status” to work again.
This worked for me 4 times in a row. Not sure if it was this illustrated process, or not. But it’s certainly worth a try if you’re having trouble recording scenes.
Now the questions
Thank you to anyone who’s reading/responding to this.
Best Wishes All
Hey everyone, I just finished my own take on a Mood Cube. Total cost - $14.xx plus 20 minutes of work.
Here are some pictures:
Here’s what I purchased to make it:
Baseball Display Case from Amazon
Vinyl Decals from Amazon
Mine looks a little rough because I eyeballed the vinyl cuts, and because the bottom face of the cube (the blue face on my build) has some plastic risers that I could have, but was way too lazy to dremel or sand off. With a straight-edge cutter and some fine grit sandpaper, one could build one that looks even better than mine! Best of all, I used up very little of the vinyl decals, so I have extra of those to refurbish my cube or use on other projects.
Enjoy!
Do you have to rotate the Cube in a special way, i only get 3 states.
I use the first gen. multi sensor
You can even modify the device handler UI attributes to make the sensor display temperature instead of being “open”, which is what I did.
Is there any chance you could share that 3D file? I’d love to have a friend print one for me, too!
That was just a prototype. The kids liked the different colors. I was working on a better design but put it aside as I’ve been totally fed-up with ST. I will work on finishing the other one over the weekend and send you the .STL files. If you want the files for the one pictured I’d be happy to send them to you.
I’d love anything you can send me! I have a friend that’s offering to print it for me, so even if it’s just a prototype that I want to improve on, it’s better than what I have (nothing). Thank you so much!
@schapper05 @jaysoncopes
Sorry this took so long. I ended up having to go out of town. Here is the link to the .STL and .123 files. I haven’t had a chance to work on the design yet. I will post the updated files once I get a chance to work on them.
Here’s another variation from @nycnickk
Has anyone experienced an issue when setting up the Mood Cube smartapp lately that when you get to the second page, it just hangs? I cannot seem to complete installation. I’ve installed smartapps a dozen times and never had issues before.
