$25 APC Back-UPS Connect BGE90M,120V, Network Backup with USB Charging ports
The price of these bounces up and down. Down to $25 again
Got 3 of these today on Newegg for $27 total. Must be signed up for their newsletter for the code I believe.
I have 2 of these already and they are not very useful for anything other than 2-prong 1.04A draws… but, if you have a use-case, here is my code that I will not be using: EMCPRRP37
Use case is to use them exactly what they are designed for. Networking equipment and IP cams.
Not sure how that happened.
I just tried, and although the code indeed works, the starting price is currently $39.99.
So, nowhere near that good of a deal… $59.97 total. :frowning:
Oh well. Was good while it lasted, I guess.
Thanks for posting about the 3-for code deal.
EDIT:
FYI, that code (from your own newegg email) is actually a $20-off code per unit. You can get one now for $20 after the code (i.e. no need to buy 3).
Yea, it was a volume discount in addition to the code. It was like $20 for 1 or 27 for 3 so I figured I might as well get 3.
Indeed. I would have as well if that deal had still been there when I got to it.
Would this work with the Smart things hub?
Works perfect for ST, HUE ,Modem, Router and you can even put a Dot and IP Cam into the USB ports
Thanks. I picked one up.
