24vac damper control?
I have a 24VAC controlled damper it has a common a open and a closed terminal which means you have to have power for both or a relay . Are there any zwave solutions out there
USA. it does not need constant power. I will take a look at it and see if that will work. Thx
I just looked at it but it says it is 110 220 and I assume that means it is the output also
I guess that could work. Lots of parts and pieces. This what I am trying to control without hooking it to a havoc system. http://www.ewccontrols.com/acrobat/090377a0165.pdf. It has its own control to figure out when it is open or closed. Basically looking for a zwave toggle switch
I think I will have the same issue with 24vac?
Really thought hard on this one and I am not sure there is anything out there but a manual toggle switch
I don’t think it’s difficult just how do you want to control the damper? With both your existing system and ST or just ST? If does it need power and wattages?
Just st. Input 110 output 24vAC. As he showed in the diagram the close can be constant 24VAC and just need a switch, from the same source, to the open. I do have a 8 channel sunfounder relay if that will help in the mix
I have a memolite. I am wondering if I can take a hot leg fron the 24vac adapter put it in the NC on the memo and then and then run a leg from the common terminal on the memo to the damper to the open position on the damper and run another leg off that adapter to the closed terminal on the damper. It appears that the memo lite can handles 24vac but needs to be powered by 16vdc
Update performed the above and works great!!!
