2015 ST Motion Sensor - No motion
I have purchased a ST Motion Sensor (2015 model) amd cannot get it to detect any motion. It will pick up the battery and temp info but no motion. When i check the recent events it just says motion stopped as soon as the device is paired.
I have removed/ reset the device multiple times and still no motion.
Any ideas?
What kind of hub do you have? Some of the older hub v1s have Zigbee firmware that could cause that kind of behavior but if that’s the case we should be able to update it.
I have the v3 hub so no issue there.
my ST original motion sensor (takes 2xAA) stopped working 2-4 weeks ago - can it be recovered? I do use hub-v1. ZigBee * Version: 1.5.4
  • Channel: 19
  • Node ID: 0000
  • Pan ID: FA98
I miss this device since it was the zigbee repeater in the garage and seemed to work well for several years. Now it only pairs, and sticks in whatever motion state it pairs with.
here is the latest log:
indent preformatted text by 4 spaces
Date Source Type Name Value User Displayed Text Changed
[2019-02-17 5:02:10.776 PM EST
1 day ago ](https://graph.api.smartthings.com/device/b42ff530-2da3-4f89-8d33-6d9651949d0f/event/acbf0580-32ff-11e9-ae9e-06ba2780e08c?all=true&source=&max=25) DEVICE ENTITY_UPDATE DeviceUpdated Device β€˜{{ deviceName }}’ updated false
[2019-02-17 5:01:10.605 PM EST
1 day ago ](https://graph.api.smartthings.com/device/b42ff530-2da3-4f89-8d33-6d9651949d0f/event/88e1cee0-32ff-11e9-b68a-1258e8184d06?all=true&source=&max=25) DEVICE ENTITY_UPDATE DeviceUpdated Device β€˜{{ deviceName }}’ updated false
[2019-02-17 5:00:52.254 PM EST
1 day ago ](https://graph.api.smartthings.com/device/b42ff530-2da3-4f89-8d33-6d9651949d0f/event/7df1aaf0-32ff-11e9-91bb-0a2c05d6ae82?all=true&source=&max=25) DEVICE ENTITY_UPDATE DeviceUpdated Device β€˜{{ deviceName }}’ updated false
[2019-02-17 5:00:52.164 PM EST
1 day ago ](https://graph.api.smartthings.com/device/b42ff530-2da3-4f89-8d33-6d9651949d0f/event/7de3ef50-32ff-11e9-91bb-0a2c05d6ae82?all=true&source=&max=25) DEVICE ENTITY_UPDATE DeviceUpdated Device β€˜{{ deviceName }}’ updated false
[2019-02-17 5:00:38.552 PM EST
1 day ago ](https://graph.api.smartthings.com/device/b42ff530-2da3-4f89-8d33-6d9651949d0f/event/75c70fa0-32ff-11e9-b68a-1258e8184d06?all=true&source=&max=25) DEVICE ENTITY_UPDATE DeviceUpdated Device β€˜{{ deviceName }}’ updated false
[2019-02-15 9:55:04.165 AM EST
3 days ago ](https://graph.api.smartthings.com/device/b42ff530-2da3-4f89-8d33-6d9651949d0f/event/ad452860-3131-11e9-baae-0691e8046f28?all=true&source=&max=25) COMMAND ping ping command was sent to GarMoSELOOKb-2AA-SsMoRpt1 true
[2019-02-12 1:09:04.119 PM EST
6 days ago ](https://graph.api.smartthings.com/device/b42ff530-2da3-4f89-8d33-6d9651949d0f/event/47fbc870-2ef1-11e9-ba17-066725efc8ea?all=true&source=&max=25)
