2 Hubs in 1 Location: Possible to switch device from one to another?
My Main v3Hub is full. I am not able to register any more (in this case: local) devices on it. But I have a second ST Hub (with a ST-Zigbee-Dongle) in this location. It is (currently) not possible to group both hubs due to limitations with regards to the ST-Dongle.
Is there any way to just “switch” one device from the registered Hub to the other one without deleting and re-integrating?
I would like to avoid deleting and re-integrating to the other hub if possible.
Couldn’t find any infos here or on the Advanced Web Application…
ST does not offer any utilities to move/migrate individual devices from one hub to another. So you would need to manually remove from one hub to add to the other.
But curious as to why you can’t add more devices to your v3 hub. Can you provide more details? How many devices are installed? Number of edge drivers installed?
Thanks @jkp,
thought as much :frowning: I don`t like doing that due to some selfmade chaos on the Homeassistant end of my setting…
Right now, there are 178 devices in this location and 176 on this v3Hub.
77 Drivers are on it, too. From 9 Driver channels - maybe I should scan and delete some of those…
