That is the version now showing under the driver infio.
Install the driver Z-Wave Button Mc from channel, this is the last version
You have to have 2 windows open with CLI, one to install it and the other to view the installation log.
I installed that version. Removed device and added again. Here are the logs. No logs when buttons are pressed. Still getting message that device hasn’t updated it’s status on the ST mobile app.
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Try the new cross-platform PowerShell Install PowerShell on Windows, Linux, and macOS - PowerShell | Microsoft Learn
PS C:\WINDOWS\system32> cd C:\SmartThings
PS C:\SmartThings> .\smartthings.exe edge:drivers:logcat
? Enter hub IP address with optionally appended port number: 10.200.10.118
connecting… failed
» Error: Connection to 10.200.10.118:9495 timed out. Ensure hub address is correct and try again
? Enter hub IP address with optionally appended port number: 10.200.10.182
Driver Id Name
1 ba2e6153-ff84-4921-b57a-bb19d4dc9387 Z-Wave Button Mc
2 0f206d13-508e-4342-9cbb-937e02489141 Z-Wave Lock
3 2cbf55e3-dbc2-48a2-8be5-4c3ce756b692 Z-Wave Switch
4 ce930ffd-8155-4dca-aaa9-6c4158fc4278 Zigbee Lock
? Select a driver. 1
connecting… connected
2023-04-02T18:15:15.707617224+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with lifecycle handlers:
DeviceLifecycleDispatcher: zwave_button
default_handlers:
driverSwitched:
added:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button
default_handlers:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button → Aeotec keyfob
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button → Fibaro keyfob
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button → Aeotec Minimote
default_handlers:
doConfigure:
child_dispatchers:
2023-04-02T18:15:15.711668932+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with Capability handlers:
CapabilityCommandDispatcher: zwave_button
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button → Aeotec keyfob
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button → Fibaro keyfob
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button → Aeotec Minimote
default_handlers:
child_dispatchers:
2023-04-02T18:15:15.712225349+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with Z-Wave handlers:
ZwaveDispatcher: zwave_button
default_handlers:
BATTERY:
REPORT
NOTIFICATION:
REPORT
CENTRAL_SCENE:
NOTIFICATION
WAKE_UP:
NOTIFICATION
SCENE_ACTIVATION:
SET
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button
default_handlers:
SCENE_ACTIVATION:
SET
CENTRAL_SCENE:
NOTIFICATION
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button → Aeotec keyfob
default_handlers:
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button → Fibaro keyfob
default_handlers:
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button → Aeotec Minimote
default_handlers:
BASIC:
SET
child_dispatchers:
2023-04-02T18:15:15.777219307+00:00 TRACE Z-Wave Button Mc Z-Wave Device: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5
Manufacturer: 0x011A Product Type: 0x0801 Product ID: 0x0B03
[0]: SCENE_CONTROLLER_CONF, ASSOCIATION, VERSION, MANUFACTURER_SPECIFIC
2023-04-02T18:15:15.784920099+00:00 TRACE Z-Wave Button Mc Received event with handler _resync
2023-04-02T18:15:15.785402724+00:00 TRACE Z-Wave Button Mc Received event with handler environment_info
2023-04-02T18:15:15.793972015+00:00 TRACE Z-Wave Button Mc Z-Wave command(1cf3026e) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T18:15:15.798868140+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button → Z-Wave multi button
2023-04-02T18:15:15.799330974+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x01”, src_channel=0, version=1}
2023-04-02T18:15:15.805214890+00:00 TRACE Z-Wave Button Mc Z-Wave command(a8a70601) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T18:15:15.806375140+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=2, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x02”, src_channel=0, version=1}
2023-04-02T18:15:15.815906140+00:00 TRACE Z-Wave Button Mc Z-Wave command(5f8900cb) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T18:15:15.816400057+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=3, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x03”, src_channel=0, version=1}
2023-04-02T18:15:15.827826349+00:00 TRACE Z-Wave Button Mc Z-Wave command(1621281e) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T18:15:15.828330849+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=4, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x04”, src_channel=0, version=1}
2023-04-02T18:15:15.837960765+00:00 TRACE Z-Wave Button Mc Z-Wave command(7c8c9a5f) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T18:15:15.838454932+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=5, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x05”, src_channel=0, version=1}
2023-04-02T18:15:15.848313307+00:00 TRACE Z-Wave Button Mc Z-Wave command(521463c0) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T18:15:15.848823682+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=6, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x06”, src_channel=0, version=1}
2023-04-02T18:15:15.859005599+00:00 TRACE Z-Wave Button Mc Z-Wave command(9621e86e) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T18:15:15.859500307+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=7, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x07”, src_channel=0, version=1}
2023-04-02T18:15:15.869282390+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T18:15:15.869980140+00:00 TRACE Z-Wave Button Mc Received event with handler environment_info
2023-04-02T18:15:15.870635682+00:00 DEBUG Z-Wave Button Mc Z-Wave hub node ID environment changed.
2023-04-02T18:15:15.879515140+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T18:15:15.881129765+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: added
2023-04-02T18:15:15.884752515+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button
2023-04-02T18:15:15.890137807+00:00 TRACE Z-Wave Button Mc Z-Wave command(1cf3026e) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T18:15:15.895291265+00:00 TRACE Z-Wave Button Mc Found CapabilityCommandDispatcher handler in zwave_button
2023-04-02T18:15:15.901290515+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button1”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T18:15:15.909318099+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button1”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T18:15:15.919573765+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“main”,“state”:{“value”:7},“visibility”:{“displayed”:false}}
2023-04-02T18:15:15.928754182+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“main”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T18:15:15.938072057+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button3”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T18:15:15.945826724+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button3”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T18:15:15.955773057+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button4”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T18:15:15.963837682+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button4”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T18:15:15.972879974+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button2”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T18:15:15.980759682+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button2”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T18:15:15.990328807+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button5”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T18:15:16.000205349+00:00 TRACE Z-Wave Button Mc Z-Wave command(a8a70601) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T18:15:16.003097807+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button5”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T18:15:16.012159599+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button6”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T18:15:16.021305724+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button6”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T18:15:16.031817182+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button7”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T18:15:16.039941515+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button7”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T18:15:16.055579640+00:00 PRINT Z-Wave Button Mc Memory >>>>>>> 1604.4453125 Kbytes
2023-04-02T18:15:16.056535140+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T18:15:16.058603932+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T18:15:16.059449474+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: doConfigure
2023-04-02T18:15:16.069363599+00:00 TRACE Z-Wave Button Mc Z-Wave command(5f8900cb) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T18:15:16.073653099+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button
2023-04-02T18:15:16.074302182+00:00 TRACE Z-Wave Button Mc Found CapabilityCommandDispatcher handler in zwave_button
2023-04-02T18:15:16.077911599+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T18:15:16.084595432+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T18:15:16.202327140+00:00 TRACE Z-Wave Button Mc Z-Wave command(1621281e) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T18:15:16.262284974+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T18:15:16.264149682+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: infoChanged
2023-04-02T18:15:16.268868140+00:00 TRACE Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> received unhandled lifecycle event: infoChanged
2023-04-02T18:15:16.270507557+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T18:15:16.289629432+00:00 TRACE Z-Wave Button Mc Z-Wave command(7c8c9a5f) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T18:15:16.379477682+00:00 TRACE Z-Wave Button Mc Z-Wave command(521463c0) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T18:15:16.479462224+00:00 TRACE Z-Wave Button Mc Z-Wave command(9621e86e) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T18:16:19.802437231+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T18:16:19.803026065+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: infoChanged
2023-04-02T18:16:19.804570981+00:00 TRACE Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> received unhandled lifecycle event: infoChanged
2023-04-02T18:16:19.805765981+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
I don’t know why the driver doesn’t get the node_id from your Hub!
I’m going to assume that your hub’s node_id is 1, you can check it in the IDE.
Install this version of the Hub to see if it sends the node_id= 1
Name Z-Wave Button Mc
Version 2023-04-02T18:35:37.544395541
Yes, node_id is “1” in this version. My node id in the IDE is “01”
Still getting “Device hasn’t updated it’s status” in the ST App.
No additional log entries after device installs, buttons not working.
Driver Id Name
2023-04-02T18:59:33.896020711+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T18:59:33.896722235+00:00 INFO Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: removed
2023-04-02T18:59:33.897707992+00:00 TRACE Z-Wave Button Mc <ZwaveDevice: fd6c33e7-6a68-4d67-8195-dfdaac7e37e5 [4E] (ZWNSC7 Enerwave Scene Master)> received unhandled lifecycle event: removed
2023-04-02T18:59:33.898349338+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T18:59:33.898959033+00:00 TRACE Z-Wave Button Mc Received event with handler driver_lifecycle
2023-04-02T18:59:33.899571643+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:01:08.425156321+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with lifecycle handlers:
default_handlers:
driverSwitched:
added:
doConfigure:
child_dispatchers:
default_handlers:
init:
child_dispatchers:
default_handlers:
doConfigure:
child_dispatchers:
default_handlers:
doConfigure:
child_dispatchers:
default_handlers:
doConfigure:
child_dispatchers:
2023-04-02T19:01:08.429609427+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with Capability handlers:
default_handlers:
refresh:
refresh
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
2023-04-02T19:01:08.430190053+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with Z-Wave handlers:
default_handlers:
BATTERY:
REPORT
NOTIFICATION:
REPORT
CENTRAL_SCENE:
NOTIFICATION
WAKE_UP:
NOTIFICATION
SCENE_ACTIVATION:
SET
child_dispatchers:
default_handlers:
SCENE_ACTIVATION:
SET
CENTRAL_SCENE:
NOTIFICATION
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
BASIC:
SET
child_dispatchers:
2023-04-02T19:01:08.495107287+00:00 TRACE Z-Wave Button Mc Z-Wave Device: a8b4afd3-0697-4980-a428-d0641cdb34aa
2023-04-02T19:01:08.495733848+00:00 TRACE Z-Wave Button Mc Received event with handler _resync
2023-04-02T19:01:08.496439454+00:00 TRACE Z-Wave Button Mc Received event with handler environment_info
2023-04-02T19:01:08.505414131+00:00 TRACE Z-Wave Button Mc Z-Wave command(d59cd92e) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:01:08.510499753+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button → Z-Wave multi button
2023-04-02T19:01:08.510965312+00:00 PRINT Z-Wave Button Mc <<<< _node_ids table: 0x159dac0
2023-04-02T19:01:08.511631104+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x01”, src_channel=0, version=1}
2023-04-02T19:01:08.517920416+00:00 TRACE Z-Wave Button Mc Z-Wave command(d7651aa9) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:01:08.519106406+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=2, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x02\x01”, src_channel=0, version=1}
2023-04-02T19:01:08.528664999+00:00 TRACE Z-Wave Button Mc Z-Wave command(15d62aa1) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:01:08.529172995+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=3, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x03\x01”, src_channel=0, version=1}
2023-04-02T19:01:08.538971177+00:00 TRACE Z-Wave Button Mc Z-Wave command(716ed58c) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:01:08.539469178+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=4, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x04\x01”, src_channel=0, version=1}
2023-04-02T19:01:08.549016360+00:00 TRACE Z-Wave Button Mc Z-Wave command(895c472b) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:01:08.549503450+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=5, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x05\x01”, src_channel=0, version=1}
2023-04-02T19:01:08.558734790+00:00 TRACE Z-Wave Button Mc Z-Wave command(12bcde1d) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:01:08.559220214+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=6, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x06\x01”, src_channel=0, version=1}
2023-04-02T19:01:08.569263523+00:00 TRACE Z-Wave Button Mc Z-Wave command(1ef8a4c0) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:01:08.569755361+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=7, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x07\x01”, src_channel=0, version=1}
2023-04-02T19:01:08.581334360+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:01:08.582241531+00:00 TRACE Z-Wave Button Mc Received event with handler environment_info
2023-04-02T19:01:08.582883252+00:00 DEBUG Z-Wave Button Mc Z-Wave hub node ID environment changed.
2023-04-02T19:01:08.593166524+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T19:01:08.594851556+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: added
2023-04-02T19:01:08.602108093+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button
2023-04-02T19:01:08.602790168+00:00 TRACE Z-Wave Button Mc Found CapabilityCommandDispatcher handler in zwave_button
2023-04-02T19:01:08.615462579+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button3”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.618819358+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button3”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.627772421+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button4”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.636751179+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button4”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.645743098+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button1”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.654788823+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button1”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.664742260+00:00 TRACE Z-Wave Button Mc Z-Wave command(d59cd92e) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:01:08.668537986+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button2”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.677106741+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button2”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.687552474+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button6”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.696869230+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button6”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.705608692+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button5”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.713981836+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button5”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.723649292+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button7”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.731996325+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button7”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.740955676+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“main”,“state”:{“value”:7},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.749922024+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“main”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:01:08.766087812+00:00 TRACE Z-Wave Button Mc Z-Wave command(d7651aa9) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:01:08.769832522+00:00 PRINT Z-Wave Button Mc Memory >>>>>>> 1699.9169921875 Kbytes
2023-04-02T19:01:08.770512890+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:01:08.771144074+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T19:01:08.771754144+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: doConfigure
2023-04-02T19:01:08.784123081+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button
2023-04-02T19:01:08.786549409+00:00 TRACE Z-Wave Button Mc Found CapabilityCommandDispatcher handler in zwave_button
2023-04-02T19:01:08.790219906+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:01:08.797398774+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:01:08.858589121+00:00 TRACE Z-Wave Button Mc Z-Wave command(15d62aa1) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:01:08.980767335+00:00 TRACE Z-Wave Button Mc Z-Wave command(716ed58c) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:01:08.984501759+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T19:01:08.984960904+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: infoChanged
2023-04-02T19:01:08.986035450+00:00 TRACE Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> received unhandled lifecycle event: infoChanged
2023-04-02T19:01:08.986687915+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:01:09.149494304+00:00 TRACE Z-Wave Button Mc Z-Wave command(895c472b) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:01:09.249530719+00:00 TRACE Z-Wave Button Mc Z-Wave command(12bcde1d) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:01:09.349548102+00:00 TRACE Z-Wave Button Mc Z-Wave command(1ef8a4c0) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:02:12.736132740+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T19:02:12.737438087+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: infoChanged
2023-04-02T19:02:12.738935837+00:00 TRACE Z-Wave Button Mc <ZwaveDevice: a8b4afd3-0697-4980-a428-d0641cdb34aa [4F] (ZWNSC7 Enerwave Scene Master)> received unhandled lifecycle event: infoChanged
2023-04-02T19:02:12.740126867+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
Groups 1-7 should now be associated with the hub and when you press each button, a scene message should be received from each association group.
When you press there is no activity in the log?
No activity after the initial enrollment. I posted everything above - even when I press buttons, nothing.
In this version I have included the configuration of scenes 1 to 7 for groups 1 to 7 and 3 seconds later I read them from the device to see what it answers
Version 2023-04-02T19:31:32.205287155
Button 1 Worked. Will test the others!
Driver Id Name
2023-04-02T19:54:50.313342220+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with lifecycle handlers:
default_handlers:
added:
doConfigure:
driverSwitched:
child_dispatchers:
default_handlers:
init:
child_dispatchers:
default_handlers:
doConfigure:
child_dispatchers:
default_handlers:
doConfigure:
child_dispatchers:
default_handlers:
doConfigure:
child_dispatchers:
2023-04-02T19:54:50.317757887+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with Capability handlers:
default_handlers:
refresh:
refresh
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
2023-04-02T19:54:50.318344345+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with Z-Wave handlers:
default_handlers:
BATTERY:
REPORT
NOTIFICATION:
REPORT
CENTRAL_SCENE:
NOTIFICATION
WAKE_UP:
NOTIFICATION
SCENE_ACTIVATION:
SET
child_dispatchers:
default_handlers:
SCENE_ACTIVATION:
SET
CENTRAL_SCENE:
NOTIFICATION
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
child_dispatchers:
default_handlers:
BASIC:
SET
child_dispatchers:
2023-04-02T19:54:50.405120054+00:00 TRACE Z-Wave Button Mc Z-Wave Device: a70feb5e-5015-4bd2-92df-8717b7c34d47
2023-04-02T19:54:50.405739929+00:00 TRACE Z-Wave Button Mc Received event with handler _resync
2023-04-02T19:54:50.406453179+00:00 TRACE Z-Wave Button Mc Received event with handler environment_info
2023-04-02T19:54:50.433944262+00:00 TRACE Z-Wave Button Mc Z-Wave command(ede6ee82) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:54:50.435621470+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button → Z-Wave multi button
2023-04-02T19:54:50.436074679+00:00 PRINT Z-Wave Button Mc <<<< _node_ids table: 0x25414d8
2023-04-02T19:54:50.436740762+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x01”, src_channel=0, version=1}
2023-04-02T19:54:50.453047470+00:00 TRACE Z-Wave Button Mc Z-Wave command(07146a29) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T19:54:50.453590637+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=1, scene_id=1}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x01\x00”, src_channel=0, version=1}
2023-04-02T19:54:50.462545179+00:00 TRACE Z-Wave Button Mc Z-Wave command(c32ebcd6) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:54:50.463032929+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=2, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x02\x01”, src_channel=0, version=1}
2023-04-02T19:54:50.479025929+00:00 TRACE Z-Wave Button Mc Z-Wave command(1fc2b665) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T19:54:50.479522720+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=2, scene_id=2}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x02\x02\x00”, src_channel=0, version=1}
2023-04-02T19:54:50.497861095+00:00 TRACE Z-Wave Button Mc Z-Wave command(bfba283b) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:54:50.498370637+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=3, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x03\x01”, src_channel=0, version=1}
2023-04-02T19:54:50.508272262+00:00 TRACE Z-Wave Button Mc Z-Wave command(8946c8ab) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T19:54:50.508780970+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=3, scene_id=3}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x03\x03\x00”, src_channel=0, version=1}
2023-04-02T19:54:50.519183220+00:00 TRACE Z-Wave Button Mc Z-Wave command(a440c695) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:54:50.519690929+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=4, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x04\x01”, src_channel=0, version=1}
2023-04-02T19:54:50.529341012+00:00 TRACE Z-Wave Button Mc Z-Wave command(0c7fc582) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T19:54:50.529846679+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=4, scene_id=4}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x04\x04\x00”, src_channel=0, version=1}
2023-04-02T19:54:50.539412012+00:00 TRACE Z-Wave Button Mc Z-Wave command(83597d6d) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:54:50.539913845+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=5, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x05\x01”, src_channel=0, version=1}
2023-04-02T19:54:50.549975845+00:00 TRACE Z-Wave Button Mc Z-Wave command(c83b75a7) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T19:54:50.550476679+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=5, scene_id=5}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x05\x05\x00”, src_channel=0, version=1}
2023-04-02T19:54:50.560793262+00:00 TRACE Z-Wave Button Mc Z-Wave command(e9a5fb32) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:54:50.561296679+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=6, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x06\x01”, src_channel=0, version=1}
2023-04-02T19:54:50.569889929+00:00 TRACE Z-Wave Button Mc Z-Wave command(ede6ee82) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:50.576025095+00:00 TRACE Z-Wave Button Mc Z-Wave command(17b85a56) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T19:54:50.576522095+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=6, scene_id=6}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x06\x06\x00”, src_channel=0, version=1}
2023-04-02T19:54:50.587809429+00:00 TRACE Z-Wave Button Mc Z-Wave command(1b791825) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T19:54:50.588320970+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=7, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x07\x01”, src_channel=0, version=1}
2023-04-02T19:54:50.598019887+00:00 TRACE Z-Wave Button Mc Z-Wave command(9c937477) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T19:54:50.598512929+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=7, scene_id=7}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x07\x07\x00”, src_channel=0, version=1}
2023-04-02T19:54:50.628436345+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:50.634891887+00:00 TRACE Z-Wave Button Mc Received event with handler environment_info
2023-04-02T19:54:50.635357054+00:00 DEBUG Z-Wave Button Mc Z-Wave hub node ID environment changed.
2023-04-02T19:54:50.640077345+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:50.641718887+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T19:54:50.644858012+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: added
2023-04-02T19:54:50.645842470+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button
2023-04-02T19:54:50.652031179+00:00 TRACE Z-Wave Button Mc Found CapabilityCommandDispatcher handler in zwave_button
2023-04-02T19:54:50.656962970+00:00 TRACE Z-Wave Button Mc Z-Wave command(07146a29) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:50.662621137+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button6”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.670903095+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button6”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.681052012+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button2”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.689651429+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button2”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.699620220+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button4”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.707783220+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button4”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.717738345+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button1”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.725663304+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button1”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.734782470+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button5”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.742770512+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button5”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.752675012+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button3”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.762622012+00:00 TRACE Z-Wave Button Mc Z-Wave command(c32ebcd6) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:50.765638679+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button3”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.774639470+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button7”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.784226679+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button7”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.794369304+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“main”,“state”:{“value”:7},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.802269429+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“main”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T19:54:50.818777679+00:00 PRINT Z-Wave Button Mc Memory >>>>>>> 1873.419921875 Kbytes
2023-04-02T19:54:50.825051012+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:50.825527304+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T19:54:50.826162762+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: doConfigure
2023-04-02T19:54:50.833209429+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button
2023-04-02T19:54:50.835053054+00:00 TRACE Z-Wave Button Mc Found CapabilityCommandDispatcher handler in zwave_button
2023-04-02T19:54:50.839908554+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:50.845790012+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:50.850963220+00:00 TRACE Z-Wave Button Mc Z-Wave command(1fc2b665) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:50.959467304+00:00 TRACE Z-Wave Button Mc Z-Wave command(bfba283b) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:51.012703387+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T19:54:51.013292429+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: infoChanged
2023-04-02T19:54:51.018700179+00:00 TRACE Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received unhandled lifecycle event: infoChanged
2023-04-02T19:54:51.020418471+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:51.049595054+00:00 TRACE Z-Wave Button Mc Z-Wave command(8946c8ab) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:51.129589179+00:00 TRACE Z-Wave Button Mc Z-Wave command(a440c695) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:51.216833512+00:00 TRACE Z-Wave Button Mc Z-Wave command(0c7fc582) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:51.316767429+00:00 TRACE Z-Wave Button Mc Z-Wave command(83597d6d) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:51.439569804+00:00 TRACE Z-Wave Button Mc Z-Wave command(c83b75a7) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:51.539593679+00:00 TRACE Z-Wave Button Mc Z-Wave command(e9a5fb32) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:51.649569346+00:00 TRACE Z-Wave Button Mc Z-Wave command(17b85a56) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:51.749572012+00:00 TRACE Z-Wave Button Mc Z-Wave command(1b791825) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:51.849619387+00:00 TRACE Z-Wave Button Mc Z-Wave command(9c937477) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:53.631248221+00:00 TRACE Z-Wave Button Mc Z-Wave command(d7d0c9d8) queued for radio transmission: CC:Association, CID:0x02
2023-04-02T19:54:53.631953512+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=1}, cmd_class=“ASSOCIATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x01”, src_channel=0, version=1}
2023-04-02T19:54:53.641185679+00:00 TRACE Z-Wave Button Mc Z-Wave command(7eb24fd9) queued for radio transmission: CC:2D, CID:0x02
2023-04-02T19:54:53.641674721+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={group_id=1}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x01”, src_channel=0, version=1}
2023-04-02T19:54:53.650548971+00:00 TRACE Z-Wave Button Mc Z-Wave command(2b2436a0) queued for radio transmission: CC:Association, CID:0x02
2023-04-02T19:54:53.651160554+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=2}, cmd_class=“ASSOCIATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x02”, src_channel=0, version=1}
2023-04-02T19:54:53.660607346+00:00 TRACE Z-Wave Button Mc Z-Wave command(fcbdf4f5) queued for radio transmission: CC:2D, CID:0x02
2023-04-02T19:54:53.661090637+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={group_id=2}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x02”, src_channel=0, version=1}
2023-04-02T19:54:53.670336846+00:00 TRACE Z-Wave Button Mc Z-Wave command(0663763b) queued for radio transmission: CC:Association, CID:0x02
2023-04-02T19:54:53.670950971+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=3}, cmd_class=“ASSOCIATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x03”, src_channel=0, version=1}
2023-04-02T19:54:53.680346387+00:00 TRACE Z-Wave Button Mc Z-Wave command(3620923d) queued for radio transmission: CC:2D, CID:0x02
2023-04-02T19:54:53.681819637+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={group_id=3}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x03”, src_channel=0, version=1}
2023-04-02T19:54:53.692474221+00:00 TRACE Z-Wave Button Mc Z-Wave command(e55a97c6) queued for radio transmission: CC:Association, CID:0x02
2023-04-02T19:54:53.693098054+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=4}, cmd_class=“ASSOCIATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x04”, src_channel=0, version=1}
2023-04-02T19:54:53.702003304+00:00 TRACE Z-Wave Button Mc Z-Wave command(75f07f9b) queued for radio transmission: CC:2D, CID:0x02
2023-04-02T19:54:53.702487512+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={group_id=4}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x04”, src_channel=0, version=1}
2023-04-02T19:54:53.712325346+00:00 TRACE Z-Wave Button Mc Z-Wave command(9d351fdd) queued for radio transmission: CC:Association, CID:0x02
2023-04-02T19:54:53.712947179+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=5}, cmd_class=“ASSOCIATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x05”, src_channel=0, version=1}
2023-04-02T19:54:53.722274054+00:00 TRACE Z-Wave Button Mc Z-Wave command(d6b130fd) queued for radio transmission: CC:2D, CID:0x02
2023-04-02T19:54:53.722762804+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={group_id=5}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x05”, src_channel=0, version=1}
2023-04-02T19:54:53.732470096+00:00 TRACE Z-Wave Button Mc Z-Wave command(d52db2db) queued for radio transmission: CC:Association, CID:0x02
2023-04-02T19:54:53.733084887+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=6}, cmd_class=“ASSOCIATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x06”, src_channel=0, version=1}
2023-04-02T19:54:53.742124387+00:00 TRACE Z-Wave Button Mc Z-Wave command(adbd797c) queued for radio transmission: CC:2D, CID:0x02
2023-04-02T19:54:53.742613137+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={group_id=6}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x06”, src_channel=0, version=1}
2023-04-02T19:54:53.752632679+00:00 TRACE Z-Wave Button Mc Z-Wave command(65128def) queued for radio transmission: CC:Association, CID:0x02
2023-04-02T19:54:53.753248054+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=7}, cmd_class=“ASSOCIATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x07”, src_channel=0, version=1}
2023-04-02T19:54:53.762911887+00:00 TRACE Z-Wave Button Mc Z-Wave command(064e8e3e) queued for radio transmission: CC:2D, CID:0x02
2023-04-02T19:54:53.763402554+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={group_id=7}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x07”, src_channel=0, version=1}
2023-04-02T19:54:53.767468679+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:53.780204721+00:00 TRACE Z-Wave Button Mc Z-Wave command(d7d0c9d8) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:53.793689346+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:53.794252429+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={grouping_identifier=1, max_nodes_supported=32, node_ids={1}, reports_to_follow=0}, cmd_class=“ASSOCIATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x01\x20\x00\x01”, src_channel=0, version=1}
2023-04-02T19:54:53.795279804+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:53.970004388+00:00 TRACE Z-Wave Button Mc Z-Wave command(7eb24fd9) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:53.981072013+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:53.981920304+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=0, group_id=1, scene_id=1}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x01\x01\x00”, src_channel=0, version=1}
2023-04-02T19:54:53.987379971+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:54.079622971+00:00 TRACE Z-Wave Button Mc Z-Wave command(2b2436a0) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:54.108789471+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:54.113352013+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={grouping_identifier=2, max_nodes_supported=32, node_ids={1}, reports_to_follow=0}, cmd_class=“ASSOCIATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x02\x20\x00\x01”, src_channel=0, version=1}
2023-04-02T19:54:54.118034221+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:54.216092179+00:00 TRACE Z-Wave Button Mc Z-Wave command(fcbdf4f5) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:54.255949804+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:54.258334054+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=0, group_id=2, scene_id=2}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x02\x02\x00”, src_channel=0, version=1}
2023-04-02T19:54:54.262508388+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:54.320284179+00:00 TRACE Z-Wave Button Mc Z-Wave command(0663763b) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:54.333486763+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:54.333945054+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={grouping_identifier=3, max_nodes_supported=32, node_ids={1}, reports_to_follow=0}, cmd_class=“ASSOCIATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x03\x20\x00\x01”, src_channel=0, version=1}
2023-04-02T19:54:54.335001804+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:54.470033221+00:00 TRACE Z-Wave Button Mc Z-Wave command(3620923d) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:54.481085471+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:54.482978888+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=0, group_id=3, scene_id=3}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x03\x03\x00”, src_channel=0, version=1}
2023-04-02T19:54:54.487450513+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:54.580153054+00:00 TRACE Z-Wave Button Mc Z-Wave command(e55a97c6) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:54.593354304+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:54.593812804+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={grouping_identifier=4, max_nodes_supported=32, node_ids={1}, reports_to_follow=0}, cmd_class=“ASSOCIATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x04\x20\x00\x01”, src_channel=0, version=1}
2023-04-02T19:54:54.594857513+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:54.715716846+00:00 TRACE Z-Wave Button Mc Z-Wave command(75f07f9b) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:54.755983554+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:54.758485846+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=0, group_id=4, scene_id=4}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x04\x04\x00”, src_channel=0, version=1}
2023-04-02T19:54:54.762695596+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:54.850045138+00:00 TRACE Z-Wave Button Mc Z-Wave command(9d351fdd) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:54.863282596+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:54.863737304+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={grouping_identifier=5, max_nodes_supported=32, node_ids={1}, reports_to_follow=0}, cmd_class=“ASSOCIATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x05\x20\x00\x01”, src_channel=0, version=1}
2023-04-02T19:54:54.864777138+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:54.915460221+00:00 TRACE Z-Wave Button Mc Z-Wave command(d6b130fd) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:54.955957513+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:54.958382013+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=0, group_id=5, scene_id=5}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x05\x05\x00”, src_channel=0, version=1}
2023-04-02T19:54:54.962548554+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:55.050003054+00:00 TRACE Z-Wave Button Mc Z-Wave command(d52db2db) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:55.065134138+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:55.065580929+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={grouping_identifier=6, max_nodes_supported=32, node_ids={1}, reports_to_follow=0}, cmd_class=“ASSOCIATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x06\x20\x00\x01”, src_channel=0, version=1}
2023-04-02T19:54:55.066564638+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:55.119950304+00:00 TRACE Z-Wave Button Mc Z-Wave command(adbd797c) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:55.163347221+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:55.169707221+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=0, group_id=6, scene_id=6}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x06\x06\x00”, src_channel=0, version=1}
2023-04-02T19:54:55.170478638+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:55.219764638+00:00 TRACE Z-Wave Button Mc Z-Wave command(65128def) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:55.230536221+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:55.231016096+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={grouping_identifier=7, max_nodes_supported=32, node_ids={1}, reports_to_follow=0}, cmd_class=“ASSOCIATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x07\x20\x00\x01”, src_channel=0, version=1}
2023-04-02T19:54:55.235336471+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:54:55.369976971+00:00 TRACE Z-Wave Button Mc Z-Wave command(064e8e3e) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T19:54:55.380724804+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:54:55.381182013+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=0, group_id=7, scene_id=7}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“\x07\x07\x00”, src_channel=0, version=1}
2023-04-02T19:54:55.384801804+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:55:43.849892753+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T19:55:43.850576169+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=“default”, scene_id=1}, cmd_class=“SCENE_ACTIVATION”, cmd_id=“SET”, dst_channels={}, encap=“NONE”, payload=“\x01\xFF”, src_channel=0, version=1}
2023-04-02T19:55:43.853165503+00:00 TRACE Z-Wave Button Mc Found ZwaveDispatcher handler in zwave_button → Z-Wave multi button
2023-04-02T19:55:43.855258336+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“button”,“capability_id”:“button”,“component_id”:“button1”,“state”:{“value”:“pushed”},“state_change”:true}
2023-04-02T19:55:43.867426628+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“button”,“capability_id”:“button”,“component_id”:“main”,“state”:{“value”:“pushed”},“state_change”:true}
2023-04-02T19:55:43.889645128+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T19:55:54.088291462+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T19:55:54.088871296+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: infoChanged
2023-04-02T19:55:54.089847296+00:00 TRACE Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received unhandled lifecycle event: infoChanged
2023-04-02T19:55:54.090497504+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
OK, Buttons 1,3,5 &7 are working, When I press then the status changes to “Pressed”.
Buttons 2,4 & 6 are not working. When I press the the status changes to “Held”
This is the trace when button 2 is pressed:
2023-04-02T20:09:26.915025552+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T20:09:26.919110968+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=“default”, scene_id=2}, cmd_class=“SCENE_ACTIVATION”, cmd_id=“SET”, dst_channels={}, encap=“NONE”, payload=“\x02\xFF”, src_channel=0, version=1}
2023-04-02T20:09:26.941363798+00:00 TRACE Z-Wave Button Mc Found ZwaveDispatcher handler in zwave_button → Z-Wave multi button
2023-04-02T20:09:26.941813022+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“button”,“capability_id”:“button”,“component_id”:“button1”,“state”:{“value”:“held”},“state_change”:true}
2023-04-02T20:09:26.986625834+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“button”,“capability_id”:“button”,“component_id”:“main”,“state”:{“value”:“held”},“state_change”:true}
2023-04-02T20:09:26.998338771+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
Try installing with CLI with this version
You do not need uninstall device
Version 2023-04-02T20:17:06.186777049
All buttons are working.
The only issue that I still see is that if you push a second button within 5 seconds of the first button, the routine does not execute. The debug shows the second button being pressed but the routine does not trigger. thoughts on this?
If you see the state change in the button’s detail view, then the routine should be triggered.
That no longer has to do with the driver
I still don’t understand why the driver can’t find the node_id of the Hub. This could be a problem if someone has more than one hub and wants to install it on one that doesn’t have node_id =1.
Please, Could you try this version to see if it works and send me the installation logs?
Version 2023-04-02T20:33:55.991932003
Here is the installation log.
PS C:\SmartThings> .\smartthings.exe edge:drivers:logcat
? Enter hub IP address with optionally appended port number: 10.200.10.182
Driver Id Name
1 ba2e6153-ff84-4921-b57a-bb19d4dc9387 Z-Wave Button Mc
2 0f206d13-508e-4342-9cbb-937e02489141 Z-Wave Lock
3 2cbf55e3-dbc2-48a2-8be5-4c3ce756b692 Z-Wave Switch
4 ce930ffd-8155-4dca-aaa9-6c4158fc4278 Zigbee Lock
? Select a driver. 1
connecting… connected
2023-04-02T20:54:37.420038241+00:00 TRACE Z-Wave Button Mc Received event with handler driver_lifecycle
2023-04-02T20:54:47.882852617+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with lifecycle handlers:
DeviceLifecycleDispatcher: zwave_button
default_handlers:
added:
doConfigure:
driverSwitched:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button
default_handlers:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button → Aeotec keyfob
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button → Fibaro keyfob
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button → Aeotec Minimote
default_handlers:
doConfigure:
child_dispatchers:
2023-04-02T20:54:47.887060117+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with Capability handlers:
CapabilityCommandDispatcher: zwave_button
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button → Aeotec keyfob
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button → Fibaro keyfob
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button → Aeotec Minimote
default_handlers:
child_dispatchers:
2023-04-02T20:54:47.887628450+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with Z-Wave handlers:
ZwaveDispatcher: zwave_button
default_handlers:
BATTERY:
REPORT
NOTIFICATION:
REPORT
CENTRAL_SCENE:
NOTIFICATION
WAKE_UP:
NOTIFICATION
SCENE_ACTIVATION:
SET
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button
default_handlers:
SCENE_ACTIVATION:
SET
CENTRAL_SCENE:
NOTIFICATION
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button → Aeotec keyfob
default_handlers:
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button → Fibaro keyfob
default_handlers:
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button → Aeotec Minimote
default_handlers:
BASIC:
SET
child_dispatchers:
2023-04-02T20:54:47.935066575+00:00 TRACE Z-Wave Button Mc Z-Wave Device: a70feb5e-5015-4bd2-92df-8717b7c34d47
Manufacturer: 0x011A Product Type: 0x0801 Product ID: 0x0B03
[0]: SCENE_CONTROLLER_CONF, ASSOCIATION, VERSION, MANUFACTURER_SPECIFIC
2023-04-02T20:54:47.935572075+00:00 TRACE Z-Wave Button Mc Received event with handler _resync
2023-04-02T20:54:47.936248284+00:00 TRACE Z-Wave Button Mc Received event with handler environment_info
2023-04-02T20:54:47.985608450+00:00 TRACE Z-Wave Button Mc Z-Wave command(2b9024bd) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T20:54:47.991300450+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button → Z-Wave multi button
2023-04-02T20:54:47.991771159+00:00 PRINT Z-Wave Button Mc <<<< _node_ids 1
2023-04-02T20:54:47.992460950+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x01”, src_channel=0, version=1}
2023-04-02T20:54:47.998662492+00:00 TRACE Z-Wave Button Mc Z-Wave command(5c897cef) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T20:54:47.999900867+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=1, scene_id=1}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x01\x00”, src_channel=0, version=1}
2023-04-02T20:54:48.009346617+00:00 TRACE Z-Wave Button Mc Z-Wave command(3d226cee) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T20:54:48.009965784+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=2, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x02\x01”, src_channel=0, version=1}
2023-04-02T20:54:48.019279950+00:00 TRACE Z-Wave Button Mc Z-Wave command(fa9ad969) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T20:54:48.019762659+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=2, scene_id=2}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x02\x02\x00”, src_channel=0, version=1}
2023-04-02T20:54:48.029123409+00:00 TRACE Z-Wave Button Mc Z-Wave command(ac178957) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T20:54:48.029738325+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=3, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x03\x01”, src_channel=0, version=1}
2023-04-02T20:54:48.041665742+00:00 TRACE Z-Wave Button Mc Z-Wave command(612918c5) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T20:54:48.042263492+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=3, scene_id=3}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x03\x03\x00”, src_channel=0, version=1}
2023-04-02T20:54:48.051679242+00:00 TRACE Z-Wave Button Mc Z-Wave command(4d2d1190) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T20:54:48.052296617+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=4, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x04\x01”, src_channel=0, version=1}
2023-04-02T20:54:48.062025575+00:00 TRACE Z-Wave Button Mc Z-Wave command(368f0640) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T20:54:48.062526325+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=4, scene_id=4}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x04\x04\x00”, src_channel=0, version=1}
2023-04-02T20:54:48.072010950+00:00 TRACE Z-Wave Button Mc Z-Wave command(82e851f8) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T20:54:48.072621575+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=5, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x05\x01”, src_channel=0, version=1}
2023-04-02T20:54:48.082627450+00:00 TRACE Z-Wave Button Mc Z-Wave command(e66ea5b4) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T20:54:48.083113867+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=5, scene_id=5}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x05\x05\x00”, src_channel=0, version=1}
2023-04-02T20:54:48.092459950+00:00 TRACE Z-Wave Button Mc Z-Wave command(cfdb28df) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T20:54:48.093070409+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=6, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x06\x01”, src_channel=0, version=1}
2023-04-02T20:54:48.102737992+00:00 TRACE Z-Wave Button Mc Z-Wave command(d92e3cde) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T20:54:48.103246325+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=6, scene_id=6}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x06\x06\x00”, src_channel=0, version=1}
2023-04-02T20:54:48.113515034+00:00 TRACE Z-Wave Button Mc Z-Wave command(cfe82f22) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T20:54:48.114183825+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=7, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x07\x01”, src_channel=0, version=1}
2023-04-02T20:54:48.122836784+00:00 TRACE Z-Wave Button Mc Z-Wave command(2b9024bd) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:48.129164159+00:00 TRACE Z-Wave Button Mc Z-Wave command(f4000d7c) queued for radio transmission: CC:2D, CID:0x01
2023-04-02T20:54:48.129650742+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={dimming_duration=0, group_id=7, scene_id=7}, cmd_class=“SCENE_CONTROLLER_CONF”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x07\x07\x00”, src_channel=0, version=1}
2023-04-02T20:54:48.144421617+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T20:54:48.148462617+00:00 TRACE Z-Wave Button Mc Received event with handler environment_info
2023-04-02T20:54:48.148909867+00:00 DEBUG Z-Wave Button Mc Z-Wave hub node ID environment changed.
2023-04-02T20:54:48.209583617+00:00 TRACE Z-Wave Button Mc Z-Wave command(5c897cef) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:48.299574367+00:00 TRACE Z-Wave Button Mc Z-Wave command(3d226cee) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:48.399565284+00:00 TRACE Z-Wave Button Mc Z-Wave command(fa9ad969) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:48.489587367+00:00 TRACE Z-Wave Button Mc Z-Wave command(ac178957) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:48.569821950+00:00 TRACE Z-Wave Button Mc Z-Wave command(612918c5) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:48.689560284+00:00 TRACE Z-Wave Button Mc Z-Wave command(4d2d1190) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:48.767935075+00:00 TRACE Z-Wave Button Mc Z-Wave command(368f0640) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:48.889619659+00:00 TRACE Z-Wave Button Mc Z-Wave command(82e851f8) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:48.967044409+00:00 TRACE Z-Wave Button Mc Z-Wave command(e66ea5b4) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:49.089580117+00:00 TRACE Z-Wave Button Mc Z-Wave command(cfdb28df) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:49.199649826+00:00 TRACE Z-Wave Button Mc Z-Wave command(d92e3cde) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:49.299614701+00:00 TRACE Z-Wave Button Mc Z-Wave command(cfe82f22) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T20:54:49.439956742+00:00 TRACE Z-Wave Button Mc Z-Wave command(f4000d7c) transmit status: TRANSMIT_COMPLETE_OK
Even though all 4 events were registered, only events 1 and 3 executed their routine. For some reason you have to wait several seconds before pushing another button or else it doesn’t execute.
Driver Id Name
2023-04-02T20:55:32.374948122+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T20:55:32.384854792+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=“default”, scene_id=1}, cmd_class=“SCENE_ACTIVATION”, cmd_id=“SET”, dst_channels={}, encap=“NONE”, payload=“\x01\xFF”, src_channel=0, version=1}
2023-04-02T20:55:32.387411804+00:00 TRACE Z-Wave Button Mc Found ZwaveDispatcher handler in zwave_button → Z-Wave multi button
2023-04-02T20:55:32.400646850+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“button”,“capability_id”:“button”,“component_id”:“button1”,“state”:{“value”:“pushed”},“state_change”:true}
2023-04-02T20:55:32.415980096+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T20:55:36.320095824+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T20:55:36.321000848+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=“default”, scene_id=3}, cmd_class=“SCENE_ACTIVATION”, cmd_id=“SET”, dst_channels={}, encap=“NONE”, payload=“\x03\xFF”, src_channel=0, version=1}
2023-04-02T20:55:36.352910212+00:00 TRACE Z-Wave Button Mc Found ZwaveDispatcher handler in zwave_button → Z-Wave multi button
2023-04-02T20:55:36.353359329+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“button”,“capability_id”:“button”,“component_id”:“button3”,“state”:{“value”:“pushed”},“state_change”:true}
2023-04-02T20:55:36.366373819+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T20:55:41.484967760+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T20:55:41.485774927+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=“default”, scene_id=3}, cmd_class=“SCENE_ACTIVATION”, cmd_id=“SET”, dst_channels={}, encap=“NONE”, payload=“\x03\xFF”, src_channel=0, version=1}
2023-04-02T20:55:41.535276469+00:00 TRACE Z-Wave Button Mc Found ZwaveDispatcher handler in zwave_button → Z-Wave multi button
2023-04-02T20:55:41.535723469+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“button”,“capability_id”:“button”,“component_id”:“button3”,“state”:{“value”:“pushed”},“state_change”:true}
2023-04-02T20:55:41.536689635+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T20:55:45.445240386+00:00 TRACE Z-Wave Button Mc Received event with handler unnamed
2023-04-02T20:55:45.445916552+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> received Z-Wave command: {args={dimming_duration=“default”, scene_id=5}, cmd_class=“SCENE_ACTIVATION”, cmd_id=“SET”, dst_channels={}, encap=“NONE”, payload=“\x05\xFF”, src_channel=0, version=1}
2023-04-02T20:55:45.448553011+00:00 TRACE Z-Wave Button Mc Found ZwaveDispatcher handler in zwave_button → Z-Wave multi button
2023-04-02T20:55:45.471873552+00:00 INFO Z-Wave Button Mc <ZwaveDevice: a70feb5e-5015-4bd2-92df-8717b7c34d47 [50] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“button”,“capability_id”:“button”,“component_id”:“button5”,“state”:{“value”:“pushed”},“state_change”:true}
2023-04-02T20:55:45.472637219+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
In the log it can be seen that the pushed events are emitted for button1, 3 twice and 5.
The execution of the routine is external to the driver, that is a matter of the routine management of the hub
Thanks for the test.
I think I’ve seen the node_id problem.
Can you please try this latest version and would it be resolved?
Name Z-Wave Button Mc
Version 2023-04-02T20:58:12.027856464
It works!
Perhaps the hub has a timeout where it ignores additional events from a multi-button device for x seconds to account for debounce.
What about that annoying message that says " this device hasn’t updated all of its status information yet. check again later."? Every time you enter the device in the ST app.
This is for Battery capability.
In this driver version deleted battery capability.
After install it, you could need delete app cache
Version 2023-04-02T22:01:25.494910798
