ZRTSI and somfy motor, question on commands
So I have this all set up now and i can control my blind up and down from smartthings…great.
However if i use the remote control that came with the motor then the state change is not registered.
Does anyone know or have a solution to this?
Is there a command I can ‘ping’ the blinds with from the smartthings device to request it’s current status? so we all play ball nicely?
There is no method to query the state.
It is best to do things thru ST, so the dth can “remember” the status.
Actually, you can set up a piston in CoRE to refresh the device on a regular basis, or it can be triggered. Mine uses motion sensors and runs refresh. Works great.
