Kilberz
(Jason)
January 7, 2021, 2:01pm
1
Hey All,
I have this ZAPATO INDOOR SIREN setup and working using a default Z-WAVE SIREN DHT.
https://www.ebay.co.uk/i/293755972866?chn=ps&mkevt=1&mkcid=28
This siren supports volume, alarm sound index (1 to 10 for different sounds), alarm music index (1 - 10) for music.
I’ve looked high and low and can’t find a DHT that works with this, I have the config options though on the bit of paper that came with it but there’s no way I could write the script.
Any advice?
You may have some luck with one of these DTH’s:
THIS HANDLER IS OBSOLETE!
A new handler was written for this device, but if you decide to use it with an existing device then you MUST remove the device, delete this handler, install/publish the new handler, and add the device again.
Information on the new handler can be found here:
IMPORTANT:
The new version of the handler doesn’t have the delayed alarm related features so if you’re happy with the functionality in this handler then you should continue using it.
This is the Official device handler for the Dome Siren (Model: DMS01)
[image] [image] [image]
[image] [image]
Alarm Features:
5 Sounds
3 Volumes
Optional LED
Customizable Duration (30 Seconds - Until Battery is Depleted)
Optional Alarm Delay with Optional Beeping (Off, 15 Seconds - 90 Se…
I won’t be converting the ZSE33 DTH into an Edge Driver so it will stop working once the Groovy platform is retired.
This is a device handler for the Zooz Smart Chime (ZSE33).
Has 10 sounds that can be used as chimes or sirens
Has 3 volume settings that can be set for chime and siren.
Optionally use flashing LED for chime and siren.
Use device as alarm to play the siren sound, switch to play the chime.
Use the customChime command to play a sound by number.
You can also select the device as a Dimming Switch from almost any SmartApp and play the 10 chimes by setting the dimming level. If you set the dimming level to 10 it will play chime 1, level 20 will play chime 2, etc.
