Hello,
I buy and test the Zipato Bulb 2 both variant Z-Wave and Zigbee with SmartThings.
They both are ok but both have bugs. This is my review and my conclusions.
The Zipato Z-Wave Zipato Bulb 2 version:
(The beautiful useless)
Plus+
- automatically recognized by SmartThings as RGBW Zigbee “Aeon LED Bulb”
- when turn power on and off it resume the last color and level (this is also a minus sometimes)
- fade in/fade out transitions
- excellent colors and output power
- price
Minus-
- do not automatically refresh the status (On/Off/) in SmartThings, in my opinion this bug is not acceptable because it do not work with buttons, pistons, routine etc. It ruins all the above qualities
- don’t have firmware update option via SmartThings
The Zipato Zigbee Bulb 2 version :
(The russian bumpkin)
Plus+
- price
- firmware update option via SmartThings desktop console
- it works
Minus-
- it is not automatically recognized by SmartThings as RGBW Zigbee bulb. It needs further settings, knowledges and resources by adding it via SmartThings desktop management console
- do not have fade in/fade out transitions
- when turn off from a color and want turn on with other color, first it turns on with the previous color then, after ~ 1 second, turns the wanted color
My conclusion in use with SmartThings:
They are beautiful color RGBW bulbs, with bugs. If they would can be managed well, by SmartThings, would a serious Hue killer. But they are clearly not mature yet for the SmartThings hub.
The Z-Wave version have more qualities than Zigbee, but a critical problem with the status refresh, which (for me), it makes it unusable for (serious) home implementations.
I definitely choose the Zigbee over Z-Wave if I want them to be used with ST.
The Z-wave bulb: If I press “Turn On” the bulb will physically turn on but the status will remain “Turning on”. If I enter in the bulb item and pres the refresh button, the status will change to ON. The same with Turn off. If I press OFF the bulb physically turn off but in the app remains on “Turning OFF”. If I go inside the item and press refresh, the status will show OFF. For this refresh bug the bulb can not be used with routines, smart apps, pistons, physical Z-Wave switches.
That’s why I will choose the Zigbee. The Zigbee works. Suddenly, without transitions, like a Russian machine, but it works.
I have attached printscreens with the tested bulbs from the ST interface. BTW, I don’t know if the Zigbee bulb can be updated ever from this interface, but at least, it has the goodwill to show a firmware option.
