New to Smartthings and in the process of converting from WiFi to Zigbee.
I have install TVRs and want to pair them with a wall thermostat. I wnat to include as many wired devices as possible to improve the mesh and not have too many batteries to change. I want to be able to adjust the room temperature using the wall mounted thermostat.
What devise should I be looking at to use as the wall termostat, it is just to control the zigbee TVR’s in the room. Any advise will be greatly appreciated.
Eugene
Welcome!
What country are you in? The device selection does vary.
When you say the wall thermostat “is just to control the Zigbee TRV’s in that room,” do you already have the TRVs? Not all Zigbee devices work with SmartThings. And some smart TRVs offer their own wall thermostat. This is often the best choice if you want a system that will work even when the SmartThings cloud is unavailable, which does happen from time to time.
HI many thanks for the reply.
I am in France.
I have some Tuya TVRs registered to Tuya Bridge.
I also have Tuya underfloor heating controls
