I am desperately after a few zigbee repeaters to improve the reliability of my presence sensors. Ideally I would like to get some smartthings outlets, but they have been out of stock for months. What else can I use? I know some people have had success with the Orvibo RGB relay, but I can’t find them in stock anywhere either…
You could try this route if you’re up for it.
That hasn’t been the community experience in the UK, they were literally flameouts with the original model and it looks like it was discontinued and they are bringing out a new one but it’s not available yet.
There’s a hive option which should work, but is expensive.
Just checked, and hive has dropped the price by £10. ![]()
https://www.amazon.co.uk/dp/B01B5P5Y6S/
Since the echo plus and smartthings use the same zigbee profile, I’ve been hoping that we would start to see more devices available.
@orangebucket started a thread in July 2018 on the Salas SP 600 zigbee pocket socket which looks to be a similar price to the hive, but is physically a bit smaller:
https://www.amazon.co.uk/SALUS-Controls-SP600-Smart-White/dp/B0743CTGJ6/
@nezmo pointed out in another thread that the Amazon.co.UK link I had for the peanut plug was for the US model. My bad.
Also, a couple of people have asked me for the link to the securifi peanut zigbee pocket socket, but I’m having trouble finding the UK version. If anyone has it please post it.
Thanks for all the useful suggestions. I hadn’t spotted that the Hive plugs are zigbee - they should do the trick.
I like the geek factor of the xbee, but is there any advantage over the Hive plug? Will the signal be stronger?
Do these hive plugs work direct with SmartThings?
I’m wanting a zigbee repeater as well.
I’ve just attached a Hive Active Plug @Steveuk23 with no issue. Finds it as a “Thing” then just update it in the IDE as a Zigbee Switch Power. Bingo. And it does give you the power too.
Thanks Roy.
Can you tell if it’s working as a Zigbee repeater ? Not sure how you’d be able to check that lol
Here’s one way, but requires the purchased of a USB stick.
Thanks I have been thinking about buying one of them to use with my Raspberry pi.
Very tricky, but I think there is a quick way. If my Xioaomi button has connected to the Hive, and I power off the socket, I’d expect my Piston to be broken. I’ll give it a whirl, fingers crossed.
Edit: Ok that didnt work, my only other way would be to power down the hub for a while, and try again.
They connected to Ikea bulbs very well. I only know this thanks to a nightmare I had with the Xiaomi contacts and a couple of buttons (all in the kitchen). They connected to the bulbs whilst the bulbs were connected to ST. Mrs kept turning the lights off at the switch, and I’d lose the lot of them. So off ST they came, and connected directly to Hue instead. Took me a bloody age to get them all sorted again. That also goes for two of the buttons in the same area. I still get the nightmares from that one lol.
Hmm so IKEA bulbs will repeat to the Xiaomi sensors?
I’ve got 2 IKEA bulbs directly onto my SmartThings so might try moving one closer to my outside shed… As that’s where my sensor is that’s struggling with a connection.
Certainly did in my experience, mine are 10 GU10’s, on the latest firmware (or they were, not sure if they’ve updated since). Once I took them all off, had to reset 16 devices to sort it out again. Then of course you get the lack of battery reporting again, and then they’d drop off again. Drove me ever so slightly mad for a while. Even now I keep opening windows every now and again to make sure they’re seen
Ha ha know what you mean.
Do you not use the smartapp "Simple device viewer"
If not I recommend it
you can set up alerts so you get notifications when a device hasn’t reported back in however many days you want.
I have a piston running twice a day and pushes out a message of either all online, or reports what is offline (more importantly
). But cheers, I’ll give that a whirl too.
Simple device viewer? Whereto get that?
Usually a search will get you to there -
https://community.smartthings.com/search?q=Simple%20device%20viewer
Several community members report the IKEA Tradfri pocket socket is working well as a zigbee repeater. Note the plug style, though.
