ZigBee or Zwave hose irrigation valve?
I’ve been looking but I am failing to find a ZigBee or Zwave irrigation valve /controller that attaches to the hose bib. I saw one by Woox.
https://wooxhome.com/products-c10/other-c4/woox-r7060-smart-garden-irrigation-control-p61
However they are not readily available here in the US. I would be very appreciative if any (poke poke @JDRoberts) would know of something like this.
This is the only one I’ve heard of, but I don’t have personal experience and it’s no longer being manufactured so you’re stuck with eBay, etc:
The other option I can think of would be to combine a normally open or normally closed 120V solenoid valve with a smart outlet - something like this (reviews are not great, there should be plenty of similar products out there):
https://www.amazon.com/Electric-Solenoid-Normally-Colsed-2W-200-20/dp/B08YDGNDBF/
Combined with adapter fittings:
https://www.amazon.com/STYDDI-Connector-Convert-Adapter-Fitting/dp/B09336JH6L/ref=sr_1_14?crid=3165ULVT1URSC&keywords=120v%2Bsolenoid%2Bvalve%2Bgarden%2Bhose%2Bthread&qid=1652712564&sprefix=120v%2Bsolenoid%2Bvalve%2Bgarden%2Bhose%2Bthread%2Caps%2C95&sr=8-14&th=1
Then program your outlet to turn on when you want the water to flow.
Yeah, as @MarkTr mentioned, I think most people just use the smart plug method with a standard dumb electric valve. You can see several project reports on this approach. At the time, a lot of people were using a Wi-Fi plug because you get better range, but as long as you can find a Z wave/Zigbee One that works where you want to put it, you can use any model.
You can see some of the project reports on the following list:
https://community.smartthings.com/tag/project_irrigation
This works fine, the only negative is that you are buying two devices instead of just one.
At our house, we use Orbit’s B-hyve, but the only integration would be through Alexa routines so it may not meet your needs. It’s Bluetooth to its own Wi-Fi bridge, then cloud cloud. We liked it because it’s battery powered and we didn’t have an outlet nearby. It’s been very reliable for us for about a year and a half.
Hi
I’m using:
Vemer VN313300 Transformer TMD 15/24 with DIN Rail for Interrupted Operation, 230 V / 12 - 24 V, Light Grey https://www.amazon.de/dp/B00F4QZENS/ref=cm_sw_r_apan_i_2261P6V4F2BPYXJE7KDG?_encoding=UTF8&psc=1
And
Rain Bird 100-HV Electric Irrigation Valve, Black, 10.7 x 8.0 x 11.5 cm https://www.amazon.de/dp/B01GOGP5X0/ref=cm_sw_r_apan_i_PRJ7VM7HZMBFC4JJKA9V?_encoding=UTF8&psc=1
With 2ch zigbee switch without problems for 2yrs now :wink:
Hi! I have that equipment, which works well with Tuya hub, but I could not add to Smartthings hub. :frowning: If anyone has a solution, I would be happy also.
