JohanW
(Johan)
December 30, 2018, 10:35am
1
I am struggling to find zigbee versions of smart in-wall switches and dimmers to install behind my existing plastic ”wall-switches” for an invisible look.
Instead of using z-wave versions (Fibaro, Qubino, Aeon).
Preferrebly on electricity to achieve a solid zigbee mesh.
I have managed to find one brand (Ubisys), but they are very expensive (120 Euro)
Please list below the ones you have found on the market!
brenthaag
(Brent Haag)
December 30, 2018, 10:28pm
2
GE/Jasco makes some…not sure where you live…these might be US only.
JohanW
(Johan)
December 30, 2018, 10:57pm
3
I live in Sweden/Europe. However zigbee should work anywhere (but size/shape of module might differ)
Do you have a link?
brenthaag
(Brent Haag)
December 30, 2018, 11:16pm
4
Those aren’t micros. They are all in one switches and they fit the US size and voltage, so I don’t think someone in Europe would be interested.
There’s an existing thread on this (this is a clickable link)
Does anyone have a link to a zigbee Micro switch. Seen a bunch of ZWAVE micro switches from Aeon Labs and Monoprice…
thanks
But the short answer is that there aren’t many. Orvibo made one for the European market, but it’s become very hard to find.
Why are you looking for zigbee instead of Z wave?
If WiFi would be an option, then you can use a Sonoff in-wall module.
Integration is a little complex, but there are lots of community members using them just because they’re so inexpensive.
[RELEASE] Sonoff, Sonoff TH, S20, Dual, 4CH, POW, & Touch Device Handler & SmartApp ($5 & $10 Smart Switches)
JohanW
(Johan)
December 31, 2018, 7:32pm
8
This is the one I have found yet. Through very expensive!
https://www.ubisys.de/en/smarthome/products-d1.html
That’s a zigbee 3.0 device. I think it will work with the newest V3 hub, although it may need custom code. It probably will not work with the older hubs.
The Orvibo relay works with the zigbee ZHA profile, and should work with any of the smartthings hubs. If you can find one to buy.
Zigbee is always zigbee, but the standard allows for different "profiles,"including manufacturer proprietary ones.
[image]
These are not all able to communicate with each other, they don’t even use the same addressing schemes.
SmartThings uses the Zigbee Home Automation profile (ZHA 1.2) and part of the Zigbee 3.0 profile. Devices using other zigbee profiles may be able to join to the network, but their communications may not be understood, or they may frequently drop off because they don’t receive a handshake message they are expecting.
There a lot of different ways to explain this, but I think one of the easiest is to think of zigbee as a post office and the different profiles as different languages. The outside envelope for different messages may look similar, have a specific format…
JohanW
(Johan)
December 31, 2018, 7:39pm
10
Son off is a very interesting option, since it is electrified it should work over time.
The reason I am planning to install my next apt with Zigbee is that I believe the speed is much faster if installing 10+ in wall dimmers/relays.
