I’m surprised that we didn’t see a message about sending enroll response. I’ve added a ‘Refresh’ button that will query the detector for both its enrollment status and the “zone type” (which I expect to be Gas Sensor 0x002b) just to make sure it’s joined properly. No need to reset and re-join. You can just update the device code, re-publish it and the refresh button should show up.
Post the live logs after pressing the refresh button. Should get a few messages back. Once we know it’s properly paired, we can start to properly debug how it’s sending the alarm messages. The 0x0003 was not what I was expecting for the alarm going off. I would have expected 0x0021 based on other IAS devices in ST.
* WZB Natural Gas Sensor
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "WZB Natural Gas", namespace: "smartthings", author: "SmartThings") {
capability "Configuration"
capability "Smoke Detector"
capability "Sensor"
capability "Refresh"
command "enrollResponse"
fingerprint profileID: "0104", deviceID: "0402", inClusters: "0000,0500", outClusters: "0500,0001"
simulator {
preferences {
input description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter \"-5\". If 3 degrees too cold, enter \"+3\".", displayDuringSetup: false, type: "paragraph", element: "paragraph"
input "tempOffset", "number", title: "Temperature Offset", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
tiles {
standardTile("smoke", "device.smoke", width: 2, height: 2) {
state("clear", label:"clear", icon:"st.alarm.smoke.clear", backgroundColor:"#ffffff")
state("detected", label:"SMOKE", icon:"st.alarm.smoke.smoke", backgroundColor:"#e86d13")
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
state "default", action:"configuration.configure", icon:"st.secondary.configure"
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat") {
state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
main (["smoke"])
details(["smoke","refresh","configure"])
log.debug "description: $description"
Map map = [:]
if (description?.startsWith('catchall:')) {
map = parseCatchAllMessage(description)
else if (description?.startsWith('read attr -')) {
map = parseReportAttributeMessage(description)
else if (description?.startsWith('zone status')) {
map = parseIasMessage(description)
log.debug "Parse returned $map"
def result = map ? createEvent(map) : null
if (description?.startsWith('enroll request')) {
List cmds = enrollResponse()
log.debug "enroll response: ${cmds}"
result = cmds?.collect { new physicalgraph.device.HubAction(it) }
return result
private Map parseCatchAllMessage(String description) {
Map resultMap = [:]
def cluster = zigbee.parse(description)
if (shouldProcessMessage(cluster)) {
log.debug "Parse $cluster"
return resultMap
private boolean shouldProcessMessage(cluster) {
// 0x0B is default response indicating message got through
// 0x07 is bind message
boolean ignoredMessage = cluster.profileId != 0x0104 ||
cluster.command == 0x0B ||
cluster.command == 0x07 ||
(cluster.data.size() > 0 && cluster.data.first() == 0x3e)
return !ignoredMessage
private Map parseReportAttributeMessage(String description) {
Map descMap = (description - "read attr - ").split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
log.debug "Desc Map: $descMap"
private Map parseIasMessage(String description) {
List parsedMsg = description.split(' ')
String msgCode = parsedMsg[2]
Map resultMap = [:]
switch(msgCode) {
case '0x0020': // Clear
resultMap = getSmokeResult('clear')
break
case '0x0021': // Smoke
resultMap = getSmokeResult('detected')
break
case '0x0022': // Tamper Alarm
break
case '0x0023': // Battery Alarm
break
case '0x0024': // Supervision Report
break
case '0x0025': // Restore Report
break
case '0x0026': // Trouble/Failure
break
case '0x0028': // Test Mode
break
return resultMap
private Map getSmokeResult(value) {
log.debug 'Gas Status'
def linkText = getLinkText(device)
def descriptionText = "${linkText} is ${value == 'detected' ? 'detected' : 'clear'}"
return [
value: value,
descriptionText: descriptionText
def refresh() { //read enrolled state and zone type from IAS cluster
"st rattr 0x${device.deviceNetworkId} ${endpointId} 0x0500 0", "delay 500",
"st rattr 0x${device.deviceNetworkId} ${endpointId} 0x0500 1"
def configure() {
String zigbeeId = swapEndianHex(device.hub.zigbeeId)
log.debug "Confuguring Reporting, IAS CIE, and Bindings."
def configCmds = [
"zcl global write 0x500 0x10 0xf0 {${zigbeeId}}", "delay 200",
"send 0x${device.deviceNetworkId} 1 ${endpointId}", "delay 1500",
//"raw 0x500 {01 23 00 00 00}", "delay 200",
//"send 0x${device.deviceNetworkId} 1 1", "delay 1500",
log.debug "configure: Write IAS CIE"
return configCmds // send refresh cmds as part of config
def enrollResponse() {
log.debug "Sending enroll response"
private hex(value) {
new BigInteger(Math.round(value).toString()).toString(16)
private String swapEndianHex(String hex) {
reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
int i = 0;
int j = array.length - 1;
byte tmp;
while (j > i) {
tmp = array[j];
array[j] = array[i];
array[i] = tmp;
j--;
i++;
return array
