Zigbee Device called "Thing"
Hello!
I just installed a zigbee dimmer from U-fairy company.
The device looks nice and they said it works with Smartthings and actually it did since Smartthings discovered it but it discovered it as a “thing” and it continues to say “Please Wait” in the ST app.
I went to IDE and tried changing the DTH to lots of thing. nothing made it work i even tried to create the DTH from the template of zigbee dimmer but no luck.
I tried removing it and pairing then waiting but still nothing
Any thoughts?
those are the list of events
raw:0000010000000000000000, dni:0000, errorCode:01, ieee:0000000000000000
catchall: 0104 EF00 01 01 0000 00 7933 01 00 0000 01 01 00080202000400000064
zbjoin: {“dni”:“7933”,“d”:“086BD7FFFEC22487”,“capabilities”:“00”,“endpoints”:[{“simple”:"01 0104 0100 00 05 0000 0003 0004 000…
catchall: 0104 0000 01 FF 0000 00 7933 00 00 0000 0A 01 010020FF
catchall: 0104 0000 01 FF 0000 00 7933 00 00 0000 0A 01 01002049
Thing added
Thing updated
Update:
I just contacted the company they said they use zigbee 3.0. does smartthings hub V2 support that?
Did you change the DTH to Zigbee Dimmer or Zigbee Dimmer Power (if the device reports watts)?
Yes i did.
I tried everything that said dimmer. Nothing worked @johnconstantelo
Come on experts.
Don’t leave me hanging :cold_sweat:
Try adding the following fingerprint to the Zigbee Dimmer DTH and then join it again:
fingerprint manufacturer:"_TYST11_583k2xfd", model: "83k2xfd"
I just tried, maybe i’m sure i did something wrong
I tried both codes below, did I do it right :smiley: ?
 *	Copyright 2015 SmartThings
 *	Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *	in compliance with the License. You may obtain a copy of the License at:
 *		http://www.apache.org/licenses/LICENSE-2.0
 *	Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *	on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *	for the specific language governing permissions and limitations under the License.
metadata {
	definition (name: "ZigBee Dimmer", namespace: "smartthings", author: "SmartThings", ocfDeviceType: "oic.d.light", runLocally: true, minHubCoreVersion: '000.019.00012', executeCommandsLocally: true, genericHandler: "Zigbee") {
		capability "Actuator"
		capability "Configuration"
		capability "Refresh"
		capability "Switch"
		capability "Switch Level"
		capability "Health Check"
		capability "Light"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "LCBulb01UK", deviceJoinName: "Aurora AOne Control Dimmer (120w)", ocfDeviceType: "oic.d.switch"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "LEEDARSON LIGHTING", model: "M350ST-W1R-01", deviceJoinName: "OZOM Dimmable LED Smart Light"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300", outClusters: "0003", manufacturer: "Aurora", model: "Dimmer", deviceJoinName: "Aurora AOne Control Dimmer (320w)", ocfDeviceType: "oic.d.switch"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B04, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY A19 ON/OFF/DIM", deviceJoinName: "SYLVANIA Smart A19 Soft White"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY A19 ON/OFF/DIM 10 Year", deviceJoinName: "SYLVANIA Smart 10-Year A19"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, FF00", outClusters: "0019", manufacturer: "MRVL", model: "MZ100", deviceJoinName: "Wemo Bulb"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05", outClusters: "0019", manufacturer: "OSRAM SYLVANIA", model: "iQBR30", deviceJoinName: "Sylvania Ultra iQ"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY PAR38 ON/OFF/DIM", deviceJoinName: "SYLVANIA Smart PAR38 Soft White"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B04, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY BR ON/OFF/DIM", deviceJoinName: "SYLVANIA Smart BR30 Soft White"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G13", deviceJoinName: "Sengled Element Classic"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G14", deviceJoinName: "Sengled Element Classic"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G23", deviceJoinName: "Sengled Element Classic"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G33", deviceJoinName: "Sengled Element Classic"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E12-N13", deviceJoinName: "Sengled Element Classic"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E12-N14", deviceJoinName: "Sengled Element Classic"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E12-N15", deviceJoinName: "Sengled Element Classic"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "DL6HD", deviceJoinName: "Leviton Dimmer Switch", ocfDeviceType: "oic.d.switch"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "DL3HL", deviceJoinName: "Leviton Lumina RF Plug-In Dimmer", ocfDeviceType: "oic.d.switch"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "DL1KD", deviceJoinName: "Leviton Lumina RF Dimmer Switch", ocfDeviceType: "oic.d.switch"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0B04, 0B05, FC01, FC08", outClusters: "0003, 0019", manufacturer: "LEDVANCE", model: "A19 W 10 year", deviceJoinName: "SYLVANIA Smart 10Y A19 Soft White"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0B05, FC01", outClusters: "0003, 0019", manufacturer: "LEDVANCE", model: "BR30 W 10 year", deviceJoinName: "SYLVANIA Smart 10Y BR30 Soft White"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0B05, FC01", outClusters: "0003, 0019", manufacturer: "LEDVANCE", model: "PAR38 W 10 year", deviceJoinName: "SYLVANIA Smart 10Y PAR38 Soft White"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "ZSD07", deviceJoinName: "Leviton Lumina RF 0-10V Dimming Wall Switch", ocfDeviceType: "oic.d.switch"
		fingerprint profileId: "0104", inClusters: "0000, 0004, 0003, 0006, 0008, 0005, FFFF, 1000", outClusters: "0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS0000", deviceJoinName: "Smart Bulb"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "LDS", model: "ZHA-DIMLight-GLS0000", deviceJoinName: "Smart Bulb"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS", deviceJoinName: "Smart Bulb"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS0044", deviceJoinName: "Smart Bulb"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0009", outClusters: "0019", manufacturer: "Aurora", model: "FWMPROZXBulb50AU", deviceJoinName: "Aurora MPro"
		fingerprint profileId: "0104", inClusters: "0000, 0004, 0003, 0006, 0008, 0005, FFFF, 1000", outClusters: "0019", manufacturer: "Aurora", model: "FWBulb51AU", deviceJoinName: "Aurora Smart Dimmable"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "FWStrip50AU", deviceJoinName: "Aurora Dimmable Strip Controller"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FEDC", outClusters: "000A, 0019", manufacturer: "Aurora", model: "FWGU10Bulb50AU", deviceJoinName: "Aurora Smart Dimmable GU10"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FEDC", outClusters: "000A, 0019", manufacturer: "Smarthome", model: "S111-201A", deviceJoinName: "Leedarson Dimmable White Bulb A19"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "innr", model: "RB 265", deviceJoinName: "Innr Smart Bulb White"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "innr", model: "RB 245", deviceJoinName: "Innr Smart Candle White"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "innr", model: "RS 225", deviceJoinName: "Innr Smart Spot White"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-N13", deviceJoinName: "Sengled Element Classic"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-N14", deviceJoinName: "Sengled Element Classic"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FEDC", outClusters: "000A, 0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS0006", deviceJoinName: "Smart Bulb"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "WallDimmerMaster", deviceJoinName: "Aurora Smart Rotary Dimmer", ocfDeviceType: "oic.d.switch"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E1A-AC2", deviceJoinName: "Sengled DownLight"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "MLI", model: "ZBT-DimmableLight", deviceJoinName: "Müller Licht Tint Bulb Dimming"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY Edge-lit flushmount", deviceJoinName: "SYLVANIA SMART+ Flush Mount"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "NPD3032", deviceJoinName: "Aurora In-line Dimmer", ocfDeviceType: "oic.d.switch"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0301, FC01", manufacturer: "ubisys", model: "D1 (5503)", deviceJoinName: "INGENIUM ZB Universal Dimming Module ZBM01d"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "Megaman", model: "AD-DimmableLight3001", deviceJoinName: "INGENIUM ZB LED Classic"
		fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", deviceId: "0101", manufacturer: "AduroSmart Eria", model: "AD-DimmableLight3001", deviceJoinName: "Eria ZigBee Dimmable Bulb"
	tiles(scale: 2) {
		multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
			tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
				attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00A0DC", nextState:"turningOff"
				attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
				attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00A0DC", nextState:"turningOff"
				attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
			tileAttribute ("device.level", key: "SLIDER_CONTROL") {
				attributeState "level", action:"switch level.setLevel"
		standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
		main "switch"
		details(["switch", "refresh"])
// Parse incoming device messages to generate events
	log.debug "description is $description"
	def event = zigbee.getEvent(description)
	if (event) {
		if (event.name=="level" && event.value==0) {}
		else {
			sendEvent(event)
	} else {
		def descMap = zigbee.parseDescriptionAsMap(description)
		if (descMap && descMap.clusterInt == 0x0006 && descMap.commandInt == 0x07) {
			if (descMap.data[0] == "00") {
				log.debug "ON/OFF REPORTING CONFIG RESPONSE: " + cluster
				sendEvent(name: "checkInterval", value: 60 * 12, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
			} else {
				log.warn "ON/OFF REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
		} else if (device.getDataValue("manufacturer") == "sengled" && descMap && descMap.clusterInt == 0x0008 && descMap.attrInt == 0x0000) {
			// This is being done because the sengled element touch/classic incorrectly uses the value 0xFF for the max level.
			// Per the ZCL spec for the UINT8 data type 0xFF is an invalid value, and 0xFE should be the max.  Here we
			// manually handle the invalid attribute value since it will be ignored by getEvent as an invalid value.
			// We also set the level of the bulb to 0xFE so future level reports will be 0xFE until it is changed by
			// something else.
			if (descMap.value.toUpperCase() == "FF") {
				descMap.value = "FE"
			sendHubCommand(zigbee.command(zigbee.LEVEL_CONTROL_CLUSTER, 0x00, "FE0000").collect { new physicalgraph.device.HubAction(it) }, 0)
			sendEvent(zigbee.getEventFromAttrData(descMap.clusterInt, descMap.attrInt, descMap.encoding, descMap.value))
		} else {
			log.warn "DID NOT PARSE MESSAGE for description : $description"
			log.debug "${descMap}"
def off() {
	zigbee.off()
def on() {
	zigbee.on()
def setLevel(value, rate = null) {
	def additionalCmds = []
	if (device.getDataValue("model") == "iQBR30" && value.toInteger() > 0) { // Handle iQ bulb not following spec
		additionalCmds = zigbee.on()
	} else if (device.getDataValue("manufacturer") == "MRVL") { // Handle marvel stack not reporting
		additionalCmds = refresh()
	zigbee.setLevel(value) + additionalCmds
 * PING is used by Device-Watch in attempt to reach the Device
def ping() {
	return zigbee.onOffRefresh()
def refresh() {
	zigbee.onOffRefresh() + zigbee.levelRefresh()
def installed() {
	if (((device.getDataValue("manufacturer") == "MRVL") && (device.getDataValue("model") == "MZ100")) || (device.getDataValue("manufacturer") == "OSRAM SYLVANIA") || (device.getDataValue("manufacturer") == "OSRAM")) {
		if ((device.currentState("level")?.value == null) || (device.currentState("level")?.value == 0)) {
			sendEvent(name: "level", value: 100)
def configure() {
	log.debug "Configuring Reporting and Bindings."
	// Device-Watch allows 2 check-in misses from device + ping (plus 1 min lag time)
	// enrolls with default periodic reporting until newer 5 min interval is confirmed
	sendEvent(name: "checkInterval", value: 2 * 10 * 60 + 1 * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
	// OnOff minReportTime 0 seconds, maxReportTime 5 min. Reporting interval if no activity
	refresh() + zigbee.onOffConfig(0, 300) + zigbee.levelConfig()
metadata {
		capability "Switch"
		capability "Light"
        fingerprint profileId: "0104", manufacturer: "U-fairy", model: "Zigbee ON/OFF/DIM", deviceJoinName: "Dimmer Switch"
	tiles(scale: 2) {
		main "switch"
	if (event) {
		else {
			sendEvent(event)
	} else {
			} else {
			// something else.
		} else {
def off() {
	zigbee.off()
def on() {
	zigbee.on()
def ping() {
def refresh() {
def installed() {
def configure() {
@Khaled_Qari I’ll send you a PM so I can get your info and give more specific advice
