I have already have a post in the Developers Section regarding this unit but I’m hoping someone here may know a device handler which will require minimal adjustment.
The device consists of two relays(switches) and two binary sensors.
It is recognised as a single Z Wave Relay in Smartthings and when the DH is changed to Dual Switch the second relay can be controlled.
I need to see the sensors, for door open/close and IR beam integration, preferably on the same device page.
The full manual for the device can be found here
All four endpoints are successfully recognised on Vera, Fibaro and Zipato systems.
Thank you.
