This device changed to profile motion-battery-illuminance-temperature in this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Z-Wave Sensor Mc
Version 2022-10-26T11:31:39.714532431
@Mariano_Colmenarejo Hello Mariano, I tell you that the sensor is giving problems and does not notify the temperature or the luminosity. You manage to verify that it could be happening. You wake it up again when it works or if you delete it and add it back. Thanks .
The only thing I did was add the temperature capability that you asked me for, the rest is the same as the stock driver.
Try with the stock driver and if the same thing happens, let smartthings know.
If it works and stops working, most likely it has to do with network problems that are occurring in the hub with the latest firmware or problems in its own Zwave network, but I donβt know.
Hi @Mariano_Colmenarejo
Can you add this one , I have modified the beta zwave sensor by adding the fingerprint , motion is working but the lux sensor seem to be not working properly , it is reporting the lux only at some time .
