Z-Wave equivalent of X10 PowerFlash Interface (LV contact input transmitter)?
x10
z-wave
(Elliott Veares) #1
I have a X10 PowerFlash interface in a box moulded above my intruder alarm that currently turns on a X10 Light switch when 12V is applied to the PowerFlash module from the alarm panel.
What is the nearest Z-Wave equivalent of the PowerFlash Interface module that would allow me to turn on a Z-Wave light switch when the auxiliary output of my intruder alarm panel outputs 12V?
Mains supply is present in moulded box above alarm panel.
#2
The Fortrezz Mimolite is popular for this kind of application.
http://www.fortrezz.com/index.php/products/mimolite
It’s also on the official compatibility list:
There are couple of other devices that can work as well and might be a bit less expensive. Also, I see a few places are out of stock on this, which may mean there will be a new model coming out, although you can still find the current one at some major retailers:
I just mention that because a number of Z wave device manufacturers are bringing out new zwave plus models this year. Those give you about 50% longer-range than the older zwave generation so could be worth waiting for if there’s one on the horizon.
@Navat604 or one of the other electricians in the community might have some additional suggestions.
(Elliott Veares) #3
I was looking at the Fortrezz Mimolite, however the following statement “Input SIG1 is an analog input, internally pulled-up to the MIMOlite supply voltage.” confused me a bit.
The device is not going to apply power to the auxiliary output (what puts out 12V DC) of my Grade 2 rated Alarm Panel and damage it is it?
#4
Tagging @johnconstantelo
#5
Thanks @JDRoberts.
I haven’t used a mimolite in that kind of scenario (yet), but I don’t believe it will. If I were you I’d contact FortrezZ at support@fortrezz.com and describe your use case. They are great to work with. Tagging @dantheman2865 for awareness.
Also, documentation on FortrezZ’s website is more current than the Zwave Products site. Be sure to check these out:
http://fortrezz.com/index.php/component/jdownloads/send/2-user-manuals/15-mimolight-user-manual
and especially this one:
http://fortrezz.com/index.php/component/jdownloads/send/3-brochures/16-mimolight-technical-appendix
Here’s another use case for a mimolite that uses more of it’s functionality through the use of a potentiometer:
(Daniel Kurin) #6
Definitely email support@fortrezz.com to get a definitive answer, but the pull-up should source 1mA or less into your equipment when you pull that MIMOlite input low.
What is the model of your panel?
