Here’s what I’m doing by combining a few apps.
This is my first stab at things. I’m sure there’s an easier way but this seems to be working so far.
(RM) created in Rules Machine
(GW) created in Gentle Wake up
® created in Routines
Here’s what I’m doing with Rules machine and Gentle wake up
This is for the kitchen lights dimmer switch
8:00 am
® Good Morning!
Turns off Alarm
Turns on kitchen lamp to 20%
Set mode to Good Morning!
Good Morning! triggers Good Morning fade (GW - Gentle Wake up)
Good Morning Fade fades Kitchen lights from current to 30% over 5 minutes
Set kitchen lamp to 50%
(RM) IF
the kitchens light sensor sees <125 Lux
and
time is between 8:06 am - 1:00 pm
then switch mode to "dim morning"
Dim Morning triggers dim morning fade(GW)
Dim morning fade fades light from current level to 60% over 10 min.
Set mode to “Cloudy Morning”
(RM) IF
the kitchens light sensor sees >=125 and <350 Lux
and
then switch mode to "bright morning"
bright Morning triggers bright morning fade(GW)
bright fade fades light from current level to 80% over 10 min.
Set mode to “Sunny Morning”
AFTERNOON
(RM) IF
and
time is between 1:01 pm - 30 mins before sunset
then switch mode to "Cloudy Afternoon"
Cloudy Afternoon triggers cloudy afternoon fade(GW)
Set mode to “Afternoon”
(RM) IF
and
then switch mode to "Bright afternoon"
Bright Afternoon triggers bright afternoon fade(GW)
bright afternoon fades light from current level to 80% over 10 min.
Set mode to “Sunny Afternoon”
EVENING
(RM) IF
the kitchens light sensor sees <10 Lux
and
time is between 30 mins before sunset and 9:00pm
then switch mode to "Dusk!"
Dusk! triggers Evening fade(GW)
Evening fade fades light from current level to 25% over 10 min.
Set mode to “Evening”
NIGHT
(RM) IF
and
time is between 9:00pm & 3:00am
then switch mode to "Night1"
Night1 triggers Night fade(GW)
Night fade fades light from current level to 15% over 10 min.
Set mode to “Night”
® Late Night Chill
Changes mode to Late Night Chill
Late Night Chill triggers Late Night Chill fade(GW)
Late Night Chill fades light from current level to 0% over 10 min.
Late Night Chill triggers LNC LED fade(GW)
LNC LED fades LED Strip from 0% to 50% over 10 mis (color purple)
Kitchen Lamp dim to 15%
(RM) If
the kitchens light sensor sees =<350 Lux
Then turn kitchen lights off
AND
Kitchen motion sensor is active**
= False – turn kitchen light off after 15 mins
= True – turn lights on
**Restricted to all modes EXCEPT Sleep, and AWAY
