Hi guys I encountered a problem a few days before six months ago this part everything was fine with the routines, basically I did a routine when you lock the door all the lights turn off but in the Smartthigs app it remains as frizzy still open I have to update it on the page and it updates to closed and activates the routine
@nayelyz @Alessio_Cimellaro which driver are you using ? What is the exact model of your lock ? What protocol are you using (Wifi, Zigbee, Thread , Z-wave )?
Can you send some CLI logs ?
The Yale Linus L2 is supposed to support Matter over Wi-Fi. Why would you be using a bridge? Also, the screenshot says the producer is August (which is puzzling since this is supposed Yale) and that the connection type is the vendor’s cloud. Doesn’t seem like a hub connected device at all.
It is connected to the Yale hub because with the direct connection with hub it was not good for me and unfortunately I had to use its hub because the distance was too far, now I would like to understand what you mean that it is not connected with hub?
I mean that the lock is not connected to a ST hub. From your screenshot, it looks like since the lock is connected to the Yale hub, the ST connection from the Yale Cloud->ST Cloud. If that is the case, you need to contact Yale to find out why the status of the lock is not being properly updated in the ST cloud. Yale controls the cloud->cloud integration.
No, it’s fixed if college account Yale and I’ll reconnect it has Smartthigs? Can it be Perrier boogie doing this? Or do you think it doesn’t change anything?
Can you open support access to your account, please? I would like to check more details about this device.
Additionally, can you test changing the lock status from the physical device, taking note of the date and time when you attempt this, and share that timestamp with us, including your time zone? For example: 14:00 GMT-6
This is to see if we don’t get any report from the Cloud-to-Cloud integration.
Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again.
To do this, do I have to be in front of the door though? Because now I’m at work I can’t update the status from the door or can I do the same and check you?
Since it’s a security device, I would suggest you be present so you can be sure that you don’t leave it unlocked accidentally.
There’s no rush, you can do the exercise, which will register logs in the Cloud if the event is being sent to SmartThings from the third-party cloud, then we’ll look for them using your timestamp. We don’t have to do this “live”.
Also, it would be useful to know if you can send commands from SmartThings to the Yale lock and if they work correctly.
Si da Smartthigs funziona bene se apro la porta e chiudo e quando parti o le routine o chiudo la porta con il telecomando Yale che non aggiorna app Smartthigs
Yes from Smartthigs it works well if I open the door and close and when you leave either the routine or I close the door with the Yale remote control that doesn’t update the Smartthigs app
Now that I’ve shared, can you fix it? And let me know? I don’t risk staying with the door open while I’m not at home? And because the first time I have these problems and I’m new to this way of Smartthigs
