Yale Conexis l1 rfid tags
Is there a way on smartthings to monitor who has unlocked the door with an rfid tag? All tags have been registered on lock and named but all i see in history is door was unlocked/ door locked.
Thanks in advance
Tagging @RBoy
The short answer is yes.
The long answer is it depends on your lock zwave module and you will need the right apps and device handlers to capture it.
Some Yale SmartLiving Keyless Connected lock like this one in UK support sending RFID tag information over zwave.
If you lock is doing that then you’ll need this device handler which can process those RFID tag events and report it SmartThings: [RELEASE] Universal Enhanced Z-Wave Lock Device Handler
If you want notifications and want to assign actions and names for those tag slots then you’ll need this app for it (or any app which recognizes the RFID information processed by the DTH above): [RELEASE] Lock User Unlock/Lock Door Notifications and Actions
Thanks for the response guys. The lock is a conexis L1 with a z wave module 2 inserted. Il try downloading the apps you mentioned and see if that works. Basically all i want to see is when the kids unlock the door coming in from school. They each have an rfid tag assigned to them so hopefully should be fairly straight forward.
Thanks again
