Freakapotamus
Please explain how to use. I hope this is also work with Xiaomi ceiling light
Freakapotamus
is not possible to not use discovery, and specify each lamp ip address? and use local API to control it?
Due to hardware limitations, Yeelights use a non-standard port for discovery, so ST can’t be used for discovery, that’s the reason for the server-in-the-middle.
But what I was trying to say is, cant we bypass discovery and add each lamp/light manually specifying the IP address, and then use Local API to control it?
The home assistant support for yeelight requires the use of developer mode if I understand correctly, I don’t really know how ST discovery works for WiFi devices
Thats exactly what I was thinking. If we enable developer mode, and skip discovery maybe its possible to control it like Home Assistant does
# Example configuration.yaml entry
light:
Another example here:
>>> bulb = Bulb("192.168.0.5")
>>> bulb.turn_on()
Do I need a Pi to get this working, or can I just install it directly onto my smart things device?
So mutch people who are asking if Samsung can let this bulbs work with Smartthings and they just don’t want to get it worked…
To bad samsung bought smartthings, flexability is gone with such a big company?
Is ie possible to install the bridge software on an Android device whats always up?
at this point, is there anyone using yeelight with ST without the IFTTT solution ?
For me… I use Alexa integration to change the colors and/or brightness.
I use a leviton outlet to turn them on or off in smarthings.
Hi All, I’ve gone through the process of installing both the RPi server and the Smartapp/Device Handler in the IDE.
One the RPi I’m seeing the following after checking the server status:
But when discovering devices in the Smartapp I’m not picking anything up. I see the following in the Live Logging:
Does the server address need to be configured somewhere? If not, is there a way to check that the server status is being represented correctly?
Any help would be appreciated…
If you have a rasberry pi laying around then install domoticz and you can use this smartapp Connection to Domoticz defined devices like Blinds and On/Off switches
to control your yeelights, tested it and works perfect.
same here; any solution that you found?
Has anyone got any further doing it this way, ie no discovery, just manual input of IP addresses ?
I currently use an ST simulated switch and the eventghost smartapp “send events to eventghost”.
I then use the yeelight python library in eventghost to switch on/off/dim the yeelight, using a python script and manually entered IP addresses and not using any discovery. Works OK but no feedback to ST if lights are switched on using the Yeelight APP.
I managed to get this working with bits and pieces of smartapp code from this forum.
No discovery needed, just find the IP of your bulb from your app / router.
This will turn a yeelight on and off only and I use a simulated switch to trigger each part.
I’m very new to this so I’m sure there must be a better way but works for me.
This snippet is used to turn it on and off:
def switchHandler(evt) {
if (evt.value == "on") {
onSwitches()
} else if (evt.value == "off") {
offSwitches()
def onSwitches() {
def String ipaddr = "192.168.1.xx"
def port = 55443
def String hexIp = ipaddr.tokenize('.').collect {
String.format('%02X', it.toInteger())
}.join()
def String hexPort = String.format('%04X', port)
def String myNetworkID = "${hexIp}:${hexPort}"
log.debug "network ID is " + myNetworkID
def transmittedData = new physicalgraph.device.HubAction("""{"id": 1, "method": "set_power", "params":["on", "smooth", 500]}\r\n""", physicalgraph.device.Protocol.LAN, myNetworkID)
transmittedData.options = [type:'LAN_TYPE_CLIENT', protocol:'LAN_PROTOCOL_TCP']
sendHubCommand(transmittedData)
def offSwitches() {
def port = 55443
}.join()
def transmittedData = new physicalgraph.device.HubAction("""{"id": 1, "method": "set_power", "params":["off", "smooth", 500]}\r\n""", physicalgraph.device.Protocol.LAN, myNetworkID)
private String convertIPtoHex(host) {
String hosthex = host.tokenize( '.' ).collect { String.format( '%02x', it.toInteger() ) }.join()
log.debug "the returned host is $hosthex"
return hosthex
private String convertPortToHex(port) {
String porthex = port.toString().format( '%04x', port.toInteger() )
log.debug "the returned port is $porthex"
return porthex
Could you please post the full DH. Is this standalone, or are you also using Eventghost as you said in the previous post?
This is a standalone smartapp, no eventghost needed.
I couldn’t figure out the device handler route so used a smart app, mainly from bits of code here and there. It is only one way, ie ST will not update if the Yeelight is changed elsewhere. I am working on this still so may have a 2 way version with dimming and colour in the future and maybe a DTH.
Heres the entire code, don’t forget to change the IP of your yeelight in the code then just create a simulated switch and in the settings of the app select it.
The Yeelight API is readily available and easy to use so may add features bit by bit.
Oh, don’t forget to turn on “Lan Control” in the Yeelight APP.
Let me know if it works OK for you
* Yeelight On and OFF
definition(
name: "Yeelight ON and OFF",
namespace: "smartthings",
author: "Simon Tether",
description: "A SmartApp that when sends URL requests to a yeelight that triggers when a simulated switch is turned on or off",
category: "Convenience",
iconUrl: "https://png.icons8.com/ultraviolet/50/000000/lamp.png",
iconX2Url: "https://png.icons8.com/ultraviolet/80/000000/lamp.png",
iconX3Url: "https://png.icons8.com/ultraviolet/80/000000/lamp.png")
preferences {
section("Send Yeelight Command to Switch") {
input "theswitch", "capability.switch", required: true, title: "Which switch?"
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
subscribe(theswitch, "switch", switchHandler)
onSwitches()
offSwitches()
def onSwitches() {
def String ipaddr = "192.168.1.131"
def port = 55443
}.join()
sendEvent(name: "switch", value: "on")
def offSwitches() {
def port = 55443
}.join()
sendEvent(name: "switch", value: "off")
EDIT: use the github code below not this snippet, it is more up to date
works on yeelight light strip.
thanks
I’ve added a bit more now and created a DTH, you can try this out if you wish. You’ll need to add a new device in the IDE and have this DTH as the type.
I still need to add 2 way communications (as it is, if you change the light status at the Yeelight app it won’t update ST) but there’s an ST problem with parsing responses from hubActions at the minute
Seems to work for me. Great work so far.
