Tof
(Christophe Sellan)
November 10, 2017, 2:25pm
#1
Hello all,
I am sur i have seen a smartapp to connect smartthings with the xiaomi mi home gateway.
I want to my xiaomi device were connected to the xiaomi gateway, and the xiaomi gateway connected to my smartthings hub.
I don’t want the xiaomi directly connected to my ST hub
I have search everywhere but can’t found,
If someone can help me
Thanks in advance
There’s nothing that connects them directly. There are some community members using a raspberry pi or other device as a “man in the middle” server and getting connection to the Xiaomi cloud that way, but it’s a lot of work to set up.
Has anyone manged to get the Xiaomi Yeelight RGBW E27 intergrated with Smartthings?
I have a couple of them laying about and a rather large area to light on an automated timer. Obviously as they’re quite cheap (around £15) it would be great if there was support for them.
Tof
(Christophe Sellan)
November 13, 2017, 7:09am
#3
Hello and thank you for your answer.
However, I’m pretty sure I’ve seen it before.
From memory it was version 2.01 or 2.1
It’s frustrating to not find it
Unless my memory betrays me
Tof
(Christophe Sellan)
December 1, 2017, 9:02am
#4
OK, i have found
So i am not totaly crazy
Announcing the new MiHome (Connect) smart app and device types. This enables you to connect Smartthings with certain MiHome Energenie products.
NOTE: This smart app requires the MiHome Gateway to function.
Author - @Alyc100
getCSSData and HTMLTile elements - @tonesto7
Tireless Testers
@Lloyd_Williams @aaf2001 @inpier
Donations
This integration is provided completely free of charge and is open source. If however you really feel like it, you can make a donation here
#Latest Versions
Ensure you install the latest versions of both the Smart App and Device Handler
IMPORTANT: If using MiHome Adapter Device Handler release dated on or before 08/11/2016, please manually remove all MiHome Adapter devices from SmartThings before upgrading to 09/11/2016 and later releases. You can re-add th…
Tof
(Christophe Sellan)
December 2, 2017, 8:22pm
#6
I just order a gatway.
I will test ans post the result
barabba9174
(Barbara Schiavinato)
December 3, 2017, 7:56am
#7
Xiaomi MiHome and MiHome Energenie are two completely different things.
They share only the name.
Tof
(Christophe Sellan)
December 3, 2017, 8:10am
#8
What’s the différents?
What i understand is i can contrôle my Xiaomi device via the gateway and it is juste what i want.
Thank you! I got confused, too.
Xiaomi is one of the largest consumer electronics products companies in China.
Coordinates: 39°55′32″N 116°26′30″E / 39.9255°N 116.4416°E / 39.9255; 116.4416 Mi.com Xiaomi Inc. (stylized as Mi) (Chinese Mandarin: [ɕjǎumì] ( listen), Chinese: 小米 科技; pinyin: Xiǎomǐ Kējì, literally "millet technology"; English: /ˌʃiːaʊˈmiː/ or /ʃiˌaʊˈmiː/) is a Chinese electronics and software company headquartered in Beijing. Xiaomi designs, develops, and sells smartphones, mobile apps, laptops and related consumer electronics. Xiaomi released its first smartphone in August 2011 and has ...
Energenie is a division of a UK company, Sandal PLC.
https://www.bloomberg.com/research/stocks/private/snapshot.asp?privcapId=183689504
So two different companies, two different countries, with two different product lines that happened to share a partial name.
The Energenie MiHome gateway
The Xiaomi Mi Smart Home Gateway
https://xiaomi-mi.com/sockets-and-sensors/xiaomi-mi-gateway-2/
Each gateway only works with its own devices, not with the devices for the other Gateway.
The Xiaomi Devices are designed to work with the Xiaomi Gateway.
But any integrations built for use with the energenie MiHome cloud will not work with the Xiaomi gateway or the Xiaomi Devices.
Tof
(Christophe Sellan)
December 3, 2017, 8:22am
#11
My Bad
Do you know if someone plan du creat à smartapp tout connect to Xiaomi api and use Xiaomi with the gateway?
