Mi|Home and Smartthings
Does any one know if MiHome energenie products work with the Smartthings Hub?
https://energenie4u.co.uk/index.phpmihome/the_range
From what I can see the sockets at least run on 433MHZ which means they won’t work directly with ST.
You could possibly use IFTTT to make something work though. There is likely a API that could be integrated with ST too but haven’t had a chance to look for any documentation.
Edit:
API is in development and there is some limited documentation:
https://mihome4u.co.uk/docs/api-documentation
I have a suspicion that it’s very similar (or the same) as LightwaveRF
I have just purchased some MiHome eTRV (radiator valves) and used their published API to plug it into SmartThings. Works well so far.
Did anybody make an progress on getting the plugs working with ST? Some of the work you’ve managed to do Alyc is really good, I’m using the hive add-on as well.
I’d happily send you a plug if it would help you configure.
Thanks.
What is the Hive add on for, I have ST and Hive thermostat
Do you where I can find it
