Hi,
I’ve successfully paired and added the latest bspranger Device Handlers, however the Door sensor doesn’t report back if the status of the switch changes.
Has anyone had a similar issue?
Thanks in advance
Keni
Hi,
Thanks in advance
Keni
Try the SmartSense Open/Closed Sensor device handler.
Nope afraid not… Still nothing
When I press the connect button quickly it seems to respond with a battery status check. So I assume the device is connected to the hub okay…
Me thinks this parrot is a dead one…
After pressing the reset button the idea logs shows it’s press, but nothing when moved.
I just purchased four of these and they work for an hour or so then disconnect. (unavailable).
I can re connect them with catch all but then they just drop again.
