I have a cree smartbulb that will not delete. Error: “Device still in use. Remove from any SmartApps or Dashboards, then try again”
I recently had to add a device back to the smart apps it said it was installed under, then remove it again then delete it… It worked so I left it alone…
I discovered a faster way…
- from the Home screen, select the device you want to remove.
- hit the hamburger icon (top right hand corner) and select “Edit”
- Select “delete device”
You are replying to a post which is four years old. Quite a few things have changed on the platform in that time. ![]()
Yeah, it’s gotten worse… /s
