Recently someone noticed many of the button actions are showing up blank in the mobile app with the Zooz Edge Drivers. This is when trying to make routines that use the buttons for a trigger. See post here: [OBSOLETE] Zooz Edge Driver Channel - #1044 by jlatis
I rolled the driver code back in a separate test channel to a version from Jan 2025, and the issue is still present in that version, so it is not related to any recent changes made to the drivers.
I think the button capability is populated correctly, unless numberOfButtons should be 2, to account for up and down?
Screenshot looks like iOS which is from the other user, I also have iOS and get the exactly same issue on my end. I have iOS 17.5, I don’t see the app version anywhere in the app, newest from app store (1.7.29).
I tested the “button” capability on Android and the issue isn’t present, so, can you provide the following info to open a report about this, please?
Open support access to your account so we can see the device’s details.
A screen recording of you entering the Routines page to create one showing those options missing. Please send it to build@smartthings.com
Please check the timestamp it’s shown in the video and let us know if it’s 12/24 hours format and your timezone (eg. GMT-6)
Same issue on my end. iPhone 14 Pro (iOS 18.3.2). Most recent Smartthings app. My screen looks exactly like Jeff’s when I try to create an automation. Tapping the switch twice shows in the app as having occurred, but I can’t map an automation to it because of the missing menu item of “Toggled up 2 Times”.
I’m having the same issue on iOS iPhone 16 pro. It seems to show all the Toggles in the “Smart Lighting App” under “Discover”, but not in the create Routine.
I’m having the same issue but found a workaround. I can create a routine from the device page for my switch. Toggle up, Toggle down, etc are all there. I created actions directly from the desired switch function and then they showed up in the Routine section.
