nickd
(Nick D)
July 11, 2016, 12:22am
1
Hey guys I just had a quick question. I’m using the following:
SmartThings Hub v2
(Honeywell) Adamco Vista 20P
EVL4
Android N
A few questions:
Are there any AlarmServers that run on the V2?
What AlarmServer do you use and recommend?
What are alarm system partitions and how do they work? The setup guide for Vista panels seems very complicated.
Search the forum and you will find several options. All require a computer or Arduino or Raspberry Pi that connects to your alarm panel. I personally use this solution with my Vista 20P:
#AD2SmartThings#
##Integrate Your Honeywell or Ademco Alarm Panel Into Your SmartThings Physical Graph##
ADT / Honeywell / Ademco / Vista / Alarm / SmartThings / Alarm Panel / Home Alarm
###A project by Stan Dotson and Michael Ritchie###
Wish you could use your existing home alarm sensors with SmartThings? Do you hate the hassle arming your panel and having to rush to disarm? Wish you could control your alarm panel on our smartphone but dont want to pay the higher monthly service bill? Do you want to install another keypad and don’t want to deal with your alarm company? Do you have an alarm panel and never use it?
This is a relatively simple project that effectively integrates your Honeywell or Ademco alarm panel with SmartThings. These panels are typically installed by ADT or other a…
You will see it mentioned in the post above but here is a solution as well
http://www.alarmdecoder.com/catalog/product_info.php/products_id/39/osCsid/oq359qlaenk7deek32r2abgkv3
