Since migration to new Smartthings application I am unable to add new devices in WebCore. Once added and selecting “Next” the only options are to cancel and discard changes. Anyone else having this issue?
That is a known display bug. Just click through and it will save the selections
Adding New or additional Devices to your Instance of webCoRE
- Select Menu (
) and touch SmartApps.
- Scroll down and tap the name of the webCoRE instance you are trying to access. This is typically webCoRE, unless you edited the name during the installation process.
- Select Settings
- Tap Available Devices
- There are two sections;
- Select devices by type: Which actuators and Which sensors
- Select devices by capability: Capability group 1-3
If you don’t find your devices in the first section, be sure to go through group 1-3 in section 2
Note: there is a display bug when exiting after you select your devices. Click Done, Next and Next again but then you will encounter Cancel, Cancel and Discard. Don’t worry - your devices you selected are saved.
