I have been tasked by the Mrs. to set up a piston that when both our phones (presence sensors) are gone from the house, the Ecobee smart thermostat would change to 74f from 70. I can’t figure out how to manage this in pistons. It doesn’t seem to trigger off. Id like to set the point to 74 or I could change the comfort setting to the Away mode as well. I would also like to reset the settings once someone comes home.
You still have a condition based “If” Block and a trigger based “If” Block. It’s a good rule to keep all Blocks either all trigger based or condition based.
Think of Triggers as action verb: Changes, Rises, Drops, Changes To/From…
Think of Conditions as “The state being” : Is, Were, Changed, Was, etc.
In your first block:
If any of phone 1 or 2 changes
Then put the rest of what you have above under it.
The second If Block is good.
You can import this one or build your own for practice. But this should work for what you need. I typically define devices so all you have to do is change that device and it will populate the all else where it’s used.
