I seem to have issues accessing the WebCore.co login site. On VPN or off VPN I get the Error 522. Reason I try both is I have a network add blocker so the VPN actually allows ALL sites. Any one else have this issue?
I can get to the main site but when I click “go to the dashboard” it errors. Is there a diffrent link or can someone post me the link for the sign in page? Kinda getting annoying only being able build routines/pistons via phone.
My Dashboard doesn’t load. after having to register logging in every time on every browser. I get “There was a problem loading the dashboard data. The Data below may be outdated. Please Log out if the problem persists.” I did that a couple of times no change. When I click on Dashboard (beta) I get a blank screen. My IDE logs " ac07ab0c-74a3-4024-8650-2c5c207b4784 12:17:56 PM: error java.lang.reflect.UndeclaredThrowableException @line 1712 (listAvailableDevices)"
When I try the dashboard from my phone, I put in the password , I get the same message as above. I click Dashboard, again blank screen and same message in IDE. I’ve changed passwords and am running version v0.3.10c.20190522. I’ve filtered devices, cleared caches, nothing works…
Did you change your ST password or webcore password? Did you run clean up and rebuild data cache in settings under your instance of webcore? Have you checked for multiple home locations? Your hub name has not changed recently - you can check in IDE.
And on your last update of the WC apps in IDE, did you make sure all apps were published?
