I had been using a smart app called weather updater to force the weather tile to update more often. Since the end of groovy this obviously no longer works and the weather tile has reverted back to the default 3 hours between updates. Not much use if you plan to use the illumination level for automations. Has anyone found a way to get the tile to update more regularly?
